Quickbooks programme will not open. It opens for a split second and closes. We installed 2003 on new computer and did not input installation key code. now it will not open.
Uninstall quicken and then reinstall it putting in key code while doing it.
https://www.quicken.com/support/how-do-i-uninstall-quicken-windows
if it won't uninstall
https://www.quicken.com/support/using-qcleanui-uninstall-quicken
SOURCE: QuickBooks has experienced an error on startup
Step one is run scandisk. If you have a cross linked or corrupted file it will sort that out automactically. Step 2 is to google "where is the quickbooks repair feature".....odds are someone has used it before. Step 3.....save your Quickbooks database (in at least two places) and delete and reinstall Quickbooks if all else fails.
SOURCE: Error message when installing QuickBooks 2005 to new 64 bit compu
to: niftyneeda, I also read that qb2005 is not compatable for vista, so that may be why you continue to hae problem, but is seems as though you found a way around it. I just purchased a new computer and also new qb. bestbuy.com had qb for 99.99 1/2 the store price.
SOURCE: is quick books 2003 Vista compatabile?
QuickBooks Pro 2003 can run on Windows Vista. Right-click a shortcut to open Quickbooks (or qbw32.exe directly) and click on Properties. Select the Compatibility tab. Under Compatibility Mode, check the box and select Windows XP (Service Pack 2) from the list. Under privilege level, select "Run this program as an administrator." Select OK and everything will work.
