I was wondering if you guys have the service manual for the sony stereo casstte deck cd player Model: HTC-Nx1...??? Thank You So Much...TLG...
Get your free service manual here
https://freeonlineservicemanual.blogspot.com/2021/07/sound-audio-sound-instrument-manual.html?showComment=1625353857089&m=1#c1718629861852162499
SOURCE: Door won't open
It might be a model that has a special IC that allows the door to open and close.
You'll need to take the case off.
try hifiengine.com...that site may have the service manual.
Kirk out
SOURCE: Sony Stereo Cassette Deck TC-WR550Z
Drives belt has become too slack to drive mechanism properly or the drive motor is bad. Have unit serviced for new belt(s)
SOURCE: Cassette Tape stuck
The problem here is that the unit is stuck in a partial position. The "reset" by unplugging and plugging back in usually causes the unit to reset to a known position. If there is no activity (no motor sound), it will need to be opened up and reset manually. If you hear the motor running for a short period, it is attempting to reset, but the belt is most likely worn or broken. These units are relatively simple, but a bit tricky to dis-assemble. This repair should not require anything other than a belt or 2. Figure on $3-$10 for parts plus the local labor rate for the repair.
Dan
