Question about Maytag Atlantis MAV6000 Top Load Washer
How open the washer Maytag MAW 6300 AWW - Maytag Atlantis MAV6000 Top Load Washer
6ya staff
SOURCE:
vince vince
  • 7 Answers
SOURCE: Washer make a loud squeak when the spinning stops
its the brake, just as long as it stops, dont worry about it, made a web page that has pics on how to replace the spin bearing on the maytag atlantis washer, after searching the net on how to, finding the manual, not explanatory, i decided to make this a simple 1 page web site, with lots of pictures, i hope this can help someone else in doing this job. since it would cost too much money for a repairman to do the job, better to buy a new one instead, i tackled the job. since it basically takes apart the whole machine, it might help others even if they dont have the spin bearing problem but other parts to replace,
http://www.geocities.com/maytagrepairwasher/
Posted on Apr 07, 2008
Larry Burke
  • 16 Answers
SOURCE: Maytag SAV 3652 AWW Washer:
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Posted on Mar 24, 2009
Anonymous
SOURCE: Maytag neptune washer mah 6500
why is my washer leaving brown black lines on my clothes
Posted on Sep 08, 2009
jimorris77
  • 411 Answers
SOURCE: I have a maytag washer with a broken belt. Model
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you
go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Dec 04, 2009
Anonymous
SOURCE: Maytag SAV 2655 AWW prblems?
Forget the "quiet pack"... when its spinning sounds can hear it no matter where you are in the house....
Posted on Jan 03, 2010
How to remove front panel on Maytag MAV7200 AWW - Washer?
Have a look at this link. You can get all informations about your washer/
http://www.appliance-repair-it.com/Maytag-washer.html
Thanks
Jul 16, 2011 | Kitchen Ranges
Have a maytag model PAV2300 Aww it grinds i have
gringing noise is never a good sign check the main bearing these are notorious for having bearings go and if it is bearing find a new machine its not worth fixing it is costs more then the machine is worth to replace
May 03, 2010 | Maytag PAV2300 Top Load Washer
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Maytag Neptune MAH 8700 AWW
NF - No Fill
It means that the Washer does not turn on water valves to fill washer with water.
Try the following steps and the problem should be solved.
1.Is the water turned on?
2.Check inlet hose screens for restriction.
3.Check wire connections in harness leading from machine control board to pressure switch.
4.Check water valve.
5.Check inputs and outputs at machine control board.
Good luck.And please do rate my answer.Thank you.
Jan 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Opening cabinate? Admiral washer AAV 7000 AWW
Soak the lid around were the rubber bumpers stop the lid from letting it slam down, mine had become almost glued, I really had to pull hard to unstick them good luck. I have never seen a top lid with a lock.
Nov 23, 2008 | Admiral AW22 Top Load Washer
take a look at epinions.com for this model
seems almost everyone's had problems with it
Nov 17, 2007 | Maytag SAV2655A Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
67 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
