Bulova Quartz Two Tone Steel Watch for Men Logo
Anonymous Posted on Feb 10, 2018
Hands only move back and forth
I have a Guess watch I bought cheap that needed a battery. After replacing the hands don't move. Only the second hand twitches. I think it needs cleaning. How do I do this. I have no money to pay someone to clean it. I have had the works out of the watch but don't know what to do after that.
Jerry Greenberg
Level 3:
Genius:
  • Master 1,691 Answers
  • Posted on Feb 11, 2018
Jerry Greenberg
Master
Level 3:
Genius:
Answers
1691
Questions
Helped
735839
Points
3767
The battery you put in may also be defective to start with. You need to have a proper watch battery tester to know if the battery is actually good.
As for cleaning a watch the watch maker will take all the tiny mechanical pieces apart, put them in to a very fine screen basket, and submerge the pieces in to the cleaning solution inside of an ultra sonic cleaning machine. Once cleaned he will maliciously re-assemble all the pieces in back in to the casing structure and lubricate with the very fine 000 viscosity oil used for watches. Then he will perform all the necessary mechanical adjustments.
Personally, if not properly trained and not having the proper tools and jigs I do not think you would be able do this type of work without ruining the watch...
5 Related Answers
Anonymous
  • 51 Answers
  • Posted on May 04, 2007
SOURCE: how to align seconds hand for stopwatch feature?
If you pull out the crown to the 2ed postion the push the upper start button that should move the second hand up to zero then push crown in.
haemoglobin
  • Posted on Feb 22, 2008
SOURCE: Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
Anonymous
  • 4889 Answers
  • Posted on Jul 28, 2008
SOURCE: Removing crown and reattaching arms
I dont think you have to remove the crown to get to the arms. If you observe cleanly you will notice that the arms are held in place by a latch on the side. That is what you have to remove to replace the arms. Good Luck!
Anonymous
  • 87 Answers
  • Posted on Jan 10, 2009
SOURCE: analogue hands don't correspode to digital clock
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are; hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t have the hands exactly opposite etc. This can all be fixed. The Synchronization function can be used:
1. Activate Crystal
2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m).
3. Push and hold (at least five seconds) the center crown
4. Watch will beep and word (SYNCHRO) will appear in the display.
5. Use the top + button to line up the minute hand right on the 12.
6. Use the bottom – button to line up the hour hand right on the 12.
7. When finished, press crown and you will go back to time.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jan 14, 2009
SOURCE: I cant adjust the minite hand backwards if the watch is gaining
Unfortunately your watch do not have reverse action, so, you have to go all the way forwards till you reach designated time again.
One more way how to set the right time is to disconnect the battery and wait till the real time reaches the hands of your watch, then put battery back and set again. If watch has a STOP function (crown pulled out), then you don't have to disconnect the battery- just pull out crown and wait.
By the way: pushing the button in accelerates minute hand constantly, but if you'll push the button rapidly, it will move mimnute hand bit by bit. Use this feature to set desired time more precisely.
Do not forget to rate, please.
1helpful
Why did hands come off during watch battery replacement?
If the hands of your watch have come off after replacing the battery, it could be due to a few different issues. Here are some possible causes and solutions:
  1. Improper installation: If the hands were not properly aligned when the battery was replaced, it could cause them to come off when the watch is turned face-up. Make sure that the hands are properly aligned and securely fastened to the watch movement before reassembling the watch.
  2. Loose or damaged hands: If the hands were loose or damaged before the battery replacement, they may have come off when the watch was turned face-up. Check the hands for any damage or wear and if necessary, replace them with new hands.
  3. Damaged watch movement: If the watch movement was damaged during the battery replacement process, it could cause the hands to come off when the watch is turned face-up. Have the watch movement inspected by a professional watch repair technician.
  4. Incorrect battery size: If the incorrect battery size was used to replace the old battery, it could cause the hands to come off when the watch is turned face-up. Make sure you are using the correct battery size and type for your watch.
  5. Incorrectly set the hands: During the battery replacement, if the hands were moved or set incorrectly, it could cause them to come off when the watch is turned face-up. Double check that the hands are set to the correct time and position.
Oct 31, 2022 • The Watches
2answers
Battery on m Invict Pro Diver watch replaced , now the second hand stays swinging back and forth in the same place
Do the minute and hour hands keep proper time? I've seen your problem before when the hand has come loose from the center post that turns it. You probably need someone who knows what they are doing to pull the crystal and reseat the second hand. Do this when the watch is off!
I just bought an Emporio Armani AR2020 wrist watch and when I received it, the hands on the watch wouldn't move. Do I need a battery for the watch? Is it broken?
That specific watch has a quartz movement, and it does not have a sweeping hand that moves to count the seconds. If the hour and minute hands are not moving there is a possibiliy that the battery has died. If after the battery is replaced and the hands still do not move then it's an issue with the quartz movement.
Dec 25, 2012 • Watches
The watch hands don't move
the battery will need changing digital and analog watches normolly have two battaries.
Nov 27, 2012 • Watches
1helpful
Hi my Guess chronograpah 123503G1 keeps getting stuck. First it appeared that the hand on the small seconds dial face was stuck. The watch wwill not keep time while this was stuck. If I shake the watch...
mcdevito75 here, Sounds like your Guess watch neds some service, cleaning, oil etc. You can check with the repairservice directory right here at fixya, bottom of this page click on repair service directory then watches.
2helpful
2answers
I have a police chronograph watch about a year old if that and the chronograph dials have reset themselves at random points does anyone know why and if so is there a fix? many thanks david
hi,
all you need to do is pull the centre bezel out (to where you adjust the time) and by pressing the top button the chronograph needle will move round. Once it is the correct place simply push the centre bezel back in.
Hope this helps.
Duncan
Hour and minute hands dont move, second hand does
You better go to a watch service center to replace depected parts ,the problem of your watch is a broken center wheel,need to replace with a new one with identical size and caliber,so its works normal again.
Hope it may help you;
Regards;
VOTIT
Apr 23, 2009 • Watches
My watch hands don't move
The best way is to go back to the shop and ask for users manual or ask to set the watch.
If you still need any further advice- upload watch model, number, all the details e.t.c.
Dec 20, 2008 • Watches
33helpful
4answers
Klik radio controlled watch
First, you need to set the hands at midnight. Press the upper button for 3 secs and let go. The hands will start to advance. Watch them, and when you are almost at the position of 00:00:00, press the upper button again briefly and the hands will stop. Then pulse the upper button to finish advancing the second hand to a perfect 00:00:00. Within 10 seconds, press the middle, knurled, button briefly (if you don’t, the watch will just to back to where it was). When you have done this, the watch will start to run (albeit at the wrong time).
Now you need to tell it to set itself from the time signal. Press the upper button and the lowest one *at the same time* for 3 secs and let go. The watch will acknowledge your request by moving the second hand (only) to 12. Leave the watch somewhere it is likely to get good radio reception. In a few minutes, you will see its hands start to move to the correct time, and they will eventually get there and your watch will be working again.
Nov 10, 2007 • Watches
Top Bulova Watches Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Bulova Watch Expert? Answer questions, earn points and help others
