ALL Drivers and Owners Manuals for
ALL Panasonic Toughbook Models are
located at the following website:
http://pc-dl.panasonic.co.jp/itn/drivers/d_menu_en.html
Make sure to select "Manual" on the menu on the
left hand side, fourth down from the top.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
SOURCE: Toughbook CF-51 Sound
You can download the XP drivers from the panasonic site. CF-51 got many flavors and be sure that your model numbers are at hand when you retrieve the factory installed drivers.
Delete all SigmaTel drivers from the registry hardware section. This would help reinstall the correct driver. The presence of these wrong registry values prevent successful installation of the factory drivers.
I have installed se7en, vista and XP successfully. The sound is really problematic since Dell and Gateway laptops use similar sound chips and offers drivers on the net... but they don't work at all. The Gateway driver seems to install perfectly from device manager report, but only the mic works & no sound.
What I do is install the factory provided drivers in XP compatible mode and then use windows update to download the latest SigmaTel drivers (se7en pre-beta). Windows got a more compatible driver but it can only install over the original since the chips cannot be recognized.
SOURCE: Panasonic CF-51 Toughbook Fn keys don't work at all
The following website contains the needed drivers:
https://eww.pavc.panasonic.co.jp/pc/cgi-bin/itn/toughbook/dl01.cgi
Select your model of CF-51 Toughbook, but you MUST be specific. There are about nine variations of the CF-51 so you must use the right drivers.
Download the hkeyapp, hkeyset, and hotkey files and unpack all files. Use the default unpack locations. If you download the files for a laptop version that is not your own, when you try to run any of these files the computer will tell you that the file is not for your model. If the files successfully unpack then you know you have the right files.
For hkeyset and hkeyapp you must run the set-up applications in the unpacked folders.
Go to Control Panel>System>Hardware>Device Manager and go to Other Devices.
The Hotkeys will appear as an "Unknown Devices" so if there is more than one, right click and choose "Update Driver".
Select "Install driver from specific location" and direct it to "C:\util2\drivers\hotkey" folder.
The computer will find the file and install the driver after which point you must restart the computer.
Hope this helps. It took me a while to figure this stuff out on my own so hope it speeds up somebody else's attempt.
Andrew
SOURCE: Panasonic Toughbook CF-51 shutting down
Sue, it's not the inverter board. People who don't really know much
about laptops will often diagnose them incorrectly, especially computer
repair shops. The problem you're experiencing is most likely related
to your motherboard. Unfortunately the most expensive part to replace on most laptops.
Your best bet is to probably just have any important files from the laptop extracted by a repair shop and then selling the computer "As-IS" on ebay. Or you could try another local repair shop to take a look at it. I wouldn't pay any money for a diagnostics since it would take most techs about 5-10 minutes to confirm what I just typed.
SOURCE: Problem with drivers of laptop Panasonic CF-51 RCVDNBE
You need to go to the followin address and register for an account. After that they will let you download you driers as needed.
http://www2.panasonic.com/webapp/wcs/stores/servlet/TCCHomePage?langId=-1&storeId=15001&catalogId=13401
Good Luck.
Hope this helps.
Please Rate
SOURCE: how to remove wireless card from panasonic cf-51?
The mini pci card or wireless is under the small access door on the bottom of the laptop. It is accessed with one screw holding the access door in place.
