Denon dvd-1920 - whirring noise once disc is loaded regardless of disc type (dvd/ cd). Any suggestions?
All the disks I've tried have, although it's only been 3 or 4 (both home-made and original). It sounds like the motor and/or the head moving around. Next week I'll go to the store I got it from and bring a DVD is particularly noisey in the drive, and try it in their floor model to see if it's this particular unit or the model in general.
Parts Of BMW.
SOURCE: not reading any type of cd or dvd
I am French I can tell you that the repair of the lens is very costly. It is practically the price of nine. Guess ...
€ 250!. On the coup's my agitated. Decevant it from yamaha. Both buy another home cinema.
SOURCE: loud mechanical noises from my dvd player during loading,advcing,
hi..the reason for the problem is u have
to clean ur dvd lense.u can clean the lense
using the lense cleaner cd.This will be available
outside.once u clean it will work properly without
any noises.
check it out.
thank u..
SOURCE: Denon 1920 DVD Player Shuts off
I've had the same problem on my 1920. Not knowing exactly what I was doing I disconnected some of the smaller boards (inside the player) from the main board powering on/off in between. When disconnecting the board fitted with the 5.1-out channels the player started up fine. Even after i reconnecting the board the player behaves normal again.
SOURCE: Denon 2910 CD player malfunctions
you could try this http://www.fixya.com/support/t244156-denon_2910_cd_player_malfunctions or clean the lens
SOURCE: I just doesn't load/read CD's.
I had the same problems with my four year Denon DVD-3910 and the only solution to it was to replace the laser unit with a new one.
There are some repair service on EBay that offer new laser units for only about 50 € and are also willing to change the laser unit for an extra charge of just 30 €.
After this replacement your Denon DVD-3910 will work fine again.
