I have just bought an epson sx435 wireless printer. I have set it up on my xp desktop with usb cable. How do I set it up to be wireless on xp and how to I set it up on my Acer Aspire one 522 netbook running windows 7.
Home > Printer
Wi-Fi Setup
Setting up a Printer Wi-Fi Network
Using the Control Panel
Using the Wi-Fi Setup Wizard
with LCD panel
WPS setup
You can set up a Wi-Fi network for your printer by using
the printer's control panel.
with LCD panel
If your printer has an LCD panel, you can use the Wi-Fi
Setup Wizard to simplify manual setup.
Note:
This setting is not available for all printers or may not be
enabled.
Make sure that the Wi-Fi is enabled on your computer in
advance.
Check the SSID and password for your network as these are
required during Wi-Fi setup. If you do not know the SSID and password, check
with your network administrator.
For step by step information on setting up a Wi-Fi
connection using the Wi-Fi Setup Wizard, click the following link. This feature
is not available for all printers or may not be enhow to set up wireless printer on windows 7 net bo - exlink.gif../p_body/panel/wizard/manual_01.htm
Well to start with xp look at the following.
http://support.epson-europe.com/onlineguides/en/sx430sx435w_nwg/html/index.htm
Testimonial: "Wally thaqnk you very much for your help. "
to install on windows 7 your printer should be picked up automatically, do not connect usb until the install wizard askes you to connect by usb, you will need install disc to install any software you may want to use. i will download the above info have a look see, if i can follow it i will let you know. so if you get stuck just ask me to help out. Wally
SOURCE: windows 7 wireless drivers
If you can try Stephan's solution first.
If that does not work try looking at the actual manufacturer's web site for your wireless card. They may have them out before Asus does.
SOURCE: How to set up wireless printing on acer aspire one
You're in luck! I found a video walk-through (that is able to explain far better than my step by step directions) for your model on how to set up a wireless connection to the printer!
You can find it here: http://h30461.www3.hp.com/index.jsp?fr_story=a52ba6ac1ea7b893a1bc67bd20d60135d4ff8c34&rf=sitemap
Just be sure that before tryint to set it up, you have the IP address of your HP Printer.
You can find this by going to the printer:
1. press the setup button (which looks like a wrench) on the fron of the printer to open the wireless menu.
2. Select PRINT REPORT, then select NETWORK CONFIG, and then press ok. In a few moments, it will print a nice sheet giving you this information.
Also, if you think you would be okay skipping the video and just running a connection wizard, you can download them with the links below (I listed quite a few as you didn’t mention which version of windows you were using):
windows xp: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-60958-2&lc=en&dlc=en&cc=us&lang=en&os=228&product=3692888
windows vista: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-60958-2&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3692888
windows 7: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-77044-1&lc=en&dlc=en&cc=us&lang=en&os=4062&product=3692888
I really hope this helps. If you need any additional assitance, don't hesitate to ask!
With Best,
TJ
SOURCE: I need windows 7 driver to 7 Acer aspire 9500
Now there's an Update from Windows Update, it's listed in the optional Updates
http://www.brighthub.com/guides/usb-flash-drive.aspx
complete guide to usb drives
at least 4gb you might be better of getting something larger say 8gb depending on your budget
hope it helps
