LG Front Load Washer - WM2301HW. Machine never had a problem spining large loads but now it wont go in to spin, it keeps stoping and trying again & again as , I have to pull out half the load to get it to spin. It never had this problem before, every large load won,t balance out
SOURCE: "CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
SOURCE: LG WM2355C water leaking under machine after washing finished.
I had this same problem and it was not the supply connections or filters! Under the machine is a rubber bellows. The bellows had sprung a leak. The part was about $10 from Sears and I repaired it in about 30 minutes. The machine is heavy so be careful. Get a friend to make sure the machine won't rock or tip when you're making the repair.
SOURCE: LG TROMM front load washer - the drum won't spin,
My Tromm washer has LE Error code I have restarted unplugged and restarted same error code keeps coming up. What does this mean?
SOURCE: My lg Tromm front load
these units have had alot of problems especially if it is on a pedistal ...they won't admit this is a problem but i have been a lg servicer for over 4 years now and see it everyday ...the unit has a stator on the rear of the tub and on the stator is a device called a hall sensor that goes bad very often... it is what controls the spped and balance of the tub..if the load starts getting unbalanced the hall sensor will tell the motor controller to slow the speed down... most likely this is your problem.... good luck please vote
