Question about Simpson Washing Machines
Efo displain simpson washer
Efo displayed through spin cycle
    Master:
  • 187 Answers
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of themachine. 1. there is a blockage in the filter or drain hose.takes too long to drain out.
Posted on Jun 08, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: beep with a display saying EFO
Dear novscorp,
According to the error code chart (a loose insert included with the operating instructions) EF0 means two things: Error 1. Over sudsing  or  Error 2. Hot water does not enter.
For over sudsing, it lists the possible causes as: a high efficiency detergent was not used (the detergent brand will have "he" on it for high efficiency) or too much detergent was added.  The solution lists: Use only a high efficiency detergent.  Follow manufacturer's recommendation for dosage.  Amount may need to be adjusted for water temperature, water hardness, load size and soil level.
For the 2nd error, hot water does not enter, it lists the possible causes as hot water hose is connected to the wrong faucet or hot water faucet is not turned on.  The solution lists: Connect hot water hose to hot water faucet and hot inlet on washer.  Be sure hot water facet is fully opened.
On a personal note, I received the same error when I mixed my detergent directly in with my color safe bleach.  It just caused a lot of suds in the machine.  One rinse cycle solved it.
Hope this helps, Ellenk4
Posted on Nov 11, 2008
chriski1
  • 6 Answers
SOURCE: washer wont go through spin cycle
Bent pinched or clooged drain hose. Other cause may be the drain filter in the front of the machine. (The small door on the lower left of the machine) With a pan, remove the cap and drain water from the small tube. Then open the larger cap and clean out the lint. This should solve the problem.
Posted on Dec 30, 2007
Anonymous
SOURCE: simpson enviro 080
there is probably something stuck in the filter. take the plastic cap off and clean it out. i had this problem and found a coin wedged in the filter part. once the coin was removed.......good as new!
Posted on Feb 09, 2009
Harjeet Singh
  • 109 Answers
SOURCE: washer doesnt spin
as you said it does rest of cyle well. then the only problem can be faulty timer. may be in spin part of timer contacts are not getting on.
Posted on Nov 25, 2009
Anonymous
  • 21 Answers
SOURCE: Simpson Esprit 700 Top Loader washer will not pump the water out
You situation could be caused by various problems. The easiest would be to check that no hoses on the drain side are kinked or plugged. This includes the tub to pump hose or the pump itself. Sometimes socks and other items can get stuck in the tub hose. Sometimes objects left in pockets can seize or hinder the pump ejection. Its sounds like if the unit is spinning and water is not ejected the above solutions should be checked first.
Posted on Feb 14, 2010
Changed lid lock on a 750 simpson ezyset washing machine.
most likely a problem program board not moving onto the next cycle and that is why the lid lock is still activated
Feb 08, 2016 | Simpson Washing Machines
My washing machine spins but doesnt complete the spin cycle
does it drain all the water out/ If not then check your pump filter.
Oct 04, 2014 | Simpson Esprit 750 Top Load 7.5kg
Is their a EFO ERROR?
Hello dbmr2 - From my research for this manufacturer there isn't any EFO error code for a washer. However, if the unit is not spinning is it making a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Contact a professional to move forward accurately to properly diagnose and repair the unit.
Dec 17, 2012 | Frigidaire ATF6000ES Front Load Washer
Efo
Hello,the EFO code is a general error that is caused because of 2 things:
1.Use of too much soap can be one of the cause of the error. to clear it run the machine through a quick cycle or normal cycle but without using the soap which will drain out the excess soap.
2. The other reason could be that the drain pipe is clogged , to clear it you can remove the back cover of the pump an remove the hose. Inspect them and clean them if nay obstruction.
Thanks
Jun 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Flashes efo on display halfway through cycle
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
May 20, 2010 | Frigidaire Affinity ATF7000E Front Load...
EFO displayed on my machine while running and beeped.
EFO is not a Kenmore Error Code.
Zanussi & AEG EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
May 15, 2009 | Kenmore 44102 Front Load Washer
My washer at the end of all the washing, spinning..etc...display the code EFO and all lights are opened...what does it mean. and I would to know if there is a listing of all the error codes and the meaning...
Dec 15, 2008 | Frigidaire Washing Machines
Washing Machines Logo
4,894 people viewed this question
Top Simpson Washing Machines Experts
ANTISPAMMER
Kardoc
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
