Panasonic Lumix DMC-LC40 Digital Camera Logo
Posted on Nov 27, 2008
How do I delete a picture on the Panasonic LUMIX DMC-LC40
Does anyone know how to delete a picture on the Panasonic LUMIX DMC-LC40. I can't figure it out.
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Nov 28, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
3611
Points
16
When reviewing the images on the LCD with the image you want to delete showing on the screen you push the button that has a trash can icon. The camera will ask you if you want to delete the file yes/no; scroll to yes and use the right arrow button to confirm.
I have a Panasonic Lumix DMC L580 and it states that the memory is full. As i dont have a manual how do i delete what is held in the memory please cheers
Are you sure of the model number? I can't find anything about a Lumix DMC-L580. There is a Lumix DMC-LS80. Make sure that you save any pictures before deleting them. Also make sure to have fresh batteries or the camera connected to AC power. If the camera runs out of power, the process will not complete.
To delete pictures from the internal memory, slide the recording/playback switch down. (The switch to the upper left of the arrow keys on the back.) This puts the camera in Play Back Mode. Use the Up/Down arrows (if needed) to select normal playback mode and press Menu/Set (in the center of the arrow keys). The delete button is the one on the right side below the arrow keys. Use the left/right buttons to select a single picture. Press delete. Press the left arrow to highlight Yes. Then press Menu/Set to confirm deleting the image. To delete multiple pictures, use the down arrow to get to Multi Delete or All Delete (instead of the left arrow). Press Menu/Set.
For All Delete, you may see an option to choose All Delete or All Delete except (star). The star indicates Favorites. If needed, pick one, press Menu/Set. Use the left arrow to select Yes and press Menu/Set again.
For Multi delete, use the left and right arrows to navigate through the stored pictures. Press the down arrow to select an image to delete. When you have marked all of the pictures that you want to delete, press Delete again. Press the up arrow to select Yes and press Menu/Set to initiate deleting these pictures. (Note: if a picture is protected, pressing the down arrow will result in On icon blinking red.)
The manual for DMC-LS80 is available from Panasonic support here: https://www.panasonic.com/au/support/manual-download/imaging/lumix-cameras/dmc-ls80.html . The current link to the manual is https://www.panasonic.com/content/dam/Panasonic/support_manual/Digital_Still_Camera/English_02-vqt3-vqt9_other/DMC-LS80%20Operating%20Instructions.pdf . See page 20 for the section on selecting the mode. See page 35 for deleting pictures.
I hope this helps.
(if you have a memory card in the camera, you will need to do the delete steps in two steps. Delete all (or multi) pictures from the internal memory and the memory card separately.)
How do I get my Panasonic Lumix DMC-FS7 to delete pictures...when I delete it says can not delete? I'm frustrated....
If the slide switch on the side of the card is in the locked position, you cannot delete....move the switch.
How do I delete pictures on my panasonic lumix dmc-FX10
Bring up the picture you want to delete and press the button with the garbage can icon...follow the on-screen instructions.
1helpful
How do I turn off the protect feature for the memory card on a Panasonic DMC LC40 digital camera?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
2helpful
How do you delete multiple pictures from the panasonic lumix DMC TZ3.  What mode and or functions on the camera do I use to delete multiple pictures at once?
The quickest way to multiple delete pictures from you camera after you have copied or backed them up is to use the camera's menu to format the camera or/and card.
Regards.
Camera issue
Likely a mem card defect. Try it in a card reader or retail store photo kiosk.
2answers
Lumix LC-DMC40 Camera Charger
what type of battery does it take? If standard AA type then a normal Ni-Mah or Ni-Cad will do it with a couple of sets of cells. Some cameras -one of mine in fact - will take AA's even though a special one is the preferred type.
Software for Lumix® Digital
No. These cameras store images in a JPEG format and can be used with any software package that can open a JPEG image.
Lumix® digital camera storage path
Unlike 35mm cameras that store images on film, Lumix® Digital Cameras store images on SD Memory Cards, which make sharing and storing your pictures easy and convenient. You simply insert an SD Memory Card into the camera, take pictures until the card is full, and then you can transfer the pictures onto a compatible PC. Once you saved all your pictures, you can erase the card and start all over again.
Unlimited consecutive shooting function?
This functionality allows unlimited consecutive shooting up to the capacity of the SD Memory Card in the camera—ideal for capturing fast-moving objects in high resolution. The number of shots may vary depending on memory card size, picture size, and compression.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
