What can I try???.....will it even recieve signal from the remote???.....how and where do I find a replacement part, if needed???
I had this problem with the LC320EMX, after extensive searching on the internet, I found a solution. The TV has entered some kind of test pattern, to escape from the flashing color test pattern do the following:
While the screen is changing from red,green,Blue,White, & Black, and is Unresposive, Take your factory remote, Press the up arrow, then the down arrow, then (ON THE TV) press the power button. Turn the set back on and it should be functioning properly. (BTW: the set gets into this test pattern if you press too many buttons on the remote, or if you use a universal remote with the wrong code)
SOURCE: I had my Emerson Tv
With the original remote. Press cursor button up followed by cursor down. Power off TV. This should return your TV back.
SOURCE: I have a new Emerson LC320EMX 32
Similar to mine, only my tv you can change channels. We either need someones help or atleast a service manual (not user manual)
SOURCE: Remote control code for dish network for Emerson
Your Dish remote was probably designed years before the Emerson set and may never have codes for it.
However, you can try the followng brands from the Dish code list to see if you can get some basic functionality:
Funai, Symphonic, Sylvania, Aventura, Durabrand,
ESA, Magnavox, INSIGNIA, Philips and Misakai
All of the above are manufactured by Funai - the least and lowest of the Japanese electronics firms.
SOURCE: Emerson TV LC320EMXF Remote code for Direc TV
I got the same TV for my stepdaughter and had the same problem. None of the Emerson codes worked. We use Dish Network but I did the autoscan thing on the remote and found that it was 672 which is listed as a Sylvania. I don't know if it will help in your case but maybe try the Sylvania codes. Good luck.
