There is a big splashy picture on the screen and you can see the background trying to open
SOURCE: My compq laptop won't start
Go to Compaq and get them to resolve the issue or replace the PC.
http://www.compaq.com/country/cpq_support.html
SOURCE: when i try to turn
If you have an external monitor or LCD monitor, try connecting it to the laptop and then turn the laptop on - if external video shows up normally then most likely you have a bad screen; if both internal and external video shows pretty much the same white lines / white outs then the system (systemboard) is most likely bad.
Could be bad ram,hard drive or possibly a bad display panel or video card.Try using different ram and removing the hard drive then try it.Also,connect it to an external display and see if it shows video or not.If after trying these things it still isn't showing let me know and i'll try to help more.
SOURCE: My asus laptop won't turn on and so I have it
may be the wire of the charger has got defect in it. check thoroughly. If your charger is OK it is problem with your motherboard.Replace it to get rid of the problem.
SOURCE: laptop won't turn on
sounds like it is either your Power Cord or Motherboard.
Contact the guys at: http://www.generalsystemsconsulting.com
They will fix it and ship it back to you by Fedex or UPS. Get a quote at any of your local computer shops, then contact them.
