SOURCE: I HAVE AN IR3225 AND
this is error code for abnormally high temperature in fixing unit.
If there isn't anything wrong with the fixing heater or thermistors you can try to clear the error code in service mode.
Procedure:
While the copier is showing error or in ready to copy mode
1) Press the asterisk key " * " on the control panel.
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " * " on the control panel.
Now on touch screen choose: COPIER>FUNCTION>CLEAR>ERR
Turn the copier off and back on.
That should do the trick.
If there is problem in heather or if the error occures again after few copies made, then you need to replace fixing film unit.
Hope that helps!
