Drills Logo
Anonymous Posted on Jun 01, 2012
BATTERY CHARGER STOPPED WORKING. MANUFACTURERS SAID WOULD BE 2 YEARS BEFORE SUPPLIES WOULD BE AVAILABLE.ANY ONE KNOW HOW TO FIX A CHARGER ??? OR MAKE ONE ?
Graham
Level 2:
Champion:
  • Expert 304 Answers
  • Posted on Jun 02, 2012
Graham
Expert
Level 2:
Champion:
Answers
304
Questions
0
Helped
149874
Points
405
You don't say which make and model number. Sometimes it is just the fuse inside, but be careful when changing it as when you turn it on again the PCB can go bang due to a fault on the board.
My Wii intec induction charger model G5857 wont charge my Wii batteries.The charger worked 4 1 year.I don't know which is the problem.I don't want 2 spend more money on a new set of batteries/charger.
first are you now using li batteries or nicad batteries
small chargers are battery composition specific
secondly-- chargers for aa /aaa batteries are cheap so get a new charger for the batteries in use
Battery charger stopped working. Can it be fixed
most laptop mfg have new chargers and cords available , but that's only if your sure its the charger and not the battery , but some laptops but not all have replaceable batterys as well , these are a little price'y especially for the older ones as there less popular
ck your mfg's web site for parts that are available
4answers
How to fix bl1830 battery when flashing red to green in charger
Take the liberty to disturb:
Our company is a Shenzhen battery factory, engaged in battery industry for 14 years, in 2010 began to set foot in the tool battery pack accessories industry, the MAKITA 18VBL1830 14.4V BL1430 opening 10.8V BL1013 series battery pack, Bosch 12V lithium battery pack and charger.Milwaukee 12V M12 1.5A 3.0A M12 M18 charger etc..Manufacturers supply quantity of large amount of pricewelcome to 86+15014034610 QQ 47018380 Mr. Miao
1helpful
2answers
I have a black & decker pivot plus that will not charge. How do I know if I need a battery or if I need a charger?
Batteries are only good for about a year, if they are older than that, take them back to the store and see if they are guaranteed at all, (all Ryobi tools and batteries have a date code on them, and they are all guaranteed for 2 years, a little plug for Ryobi,) that is all I buy now days, they work great. So, to check your charger, you will need a volt meter set on 12 or 20 v dc, and see if the charger is putting out, if not, then, the cost of a new ryobi might be the same as the fix for the black and decker. That is if you use the thing, we use our cordless tools every day and charge them every night, hope this helps.
2answers
Hi I have the vivitar vivicam 8025 dont have my manual want to know how to charge my battery
First off, you can download a PDF version of the manual from the manufacturer at: http://www.vivitar.com/files_products/13/VC8025%20User%20Manual.pdf
If you don't have a PDF viewer, you can download one from: http://www.foxitsoftware.com/pdf/reader/ (just click download under the free version)
For your convenience I've pasted the relevant information about charging the batteries from the above manual:
Please charge the battery as below 2 methods: A. Charge with USB cable Insert the lithium battery into your camera correctly, and connect your camera to computer with USB cable. The red LED of camera will be light on indicating that your camera is in charging status, the LED willbe off when charge full.
B. Charge with supplied charger Your camera is supplied a compatible charger for you, you are only required to put the battery into charger and charge the lithium battery directly from electrical outlet
Please leave feedback if this was helpful. Thanks.
3answers
Battery problem with nx9010
well battary does have some life and now u r telling that u r using after 2 years... i ll suggest you to buy a new one rather go for maintenace.
I have a Sny dcr-hc48 camcorder which stopped working some time back. this week i had my friend who came with the same camcorder and i swapped in his battery and my camcorder started working. but if i...
First: put your battery in your friends camcorder and use ur friends charger to charge the battery.
Then put your battery back into your camcorder to see if it works.
If the battery works then this eliminates the battery as a problem.
Next plug your charger into your friends camcorder to see if it will power the camcorder without battery, if this works then the problem will most likley be the connector in your camcorder.
If this does not work then the problem will be the plug or the charger.
Next plug your friends charger into your camcorder if it does not work this will verify that the problem is the connector on your camcorder
binary6
3answers
How to charge battery in Motorola Talkabout Distance DPS
You can obtain a wall adapter style charger for your radio at your local Motorola dealer, or online at http://www.eradiostore.com/cart/index.php?target=products&mode=search&subcats=Y&type=extended&avail=Y&pshort=Y&pfull=Y&pname=Y&epcode=Y&q=htn8232
Sidenote: The rechargeable battery is good for about 2 to 3 years. You can tell the age of your battery by looking at the date code on the back of the battery above the stop sign. The first number is the year, the next two numbers are the week of the year. 915 would be 2009 the 15th week. (Or if very old it could be 1999 the 15th week.) A good battery, when charged will go an 8-10 hour day.
Keep both of your charge trays, replacements for these are no longer available.
2answers
Magellan 2000 doesn't power up
try replacing the battery. ususally if the battery is dead it will freeze or not turn on. if this doesn't work magellan will replace it with a new one at a very reasonable price. I just replaced a magellan 800 with a magellan 3210 for $132.00. your may get a better deal. call magellan
if you have an a/c 110 volt to 5 volt converter for the magellan, try charging it in the house with that one rather than the car charger.
Problem with sony dsc p92 - operation and battery life
try to switch to rechargeable Ni-MH batteries, i'm not sure it supposed to work properly with Alkaline, that's why Sony supplied battery charger and their Stamina batteries with this camera
Top Drills Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you a Drill Expert? Answer questions, earn points and help others
