SOURCE: Japanese to English?
1.find a japanese person and ask him to do it for you
2.find an english manual and follow the same steps
3.find an online translator and try to translate the steps
(those are working if your camera support english language)
SOURCE: CHANGE JAPANESE TO ENGLISH INSTRUCTIONS
most of the nv-gs50 cannot support multi-language (i.e. the ones manu/bought in japan).
you may be able to find a firmware update, but i would not recommend it---i.e. you are stuck with japanese
SOURCE: unit language
Download the driver from the site then in the help menu go to the language setup. You might have to guess your way around in this but refer to Panasonics other insturuction manuals you should know when you scroll to the english section.
Also refered to as nv-gs50e or nv-gs70e. Go to http://www2.panasonic.com/consumer-electronics/support/Drivers-and-Downloads/list-75489-Camcorders#Anchor_13 it will be the third driver from the BOTTOM. This model has been discontinued so support for later windows editions are not likely. Windows 2000 is the last version you can always run your compatabilty mode with 2000 for optimum preformance.
PAL Mini-DV Cameras/recorder
NV-GS50E
SOURCE: my cam is in japanese
I would search japanese text for words like the word language and maybe the word settings. Most instruction manuals lay out the actual menu procedure, you will have to search *** character text for all the words in the menu to get back to the language option. Good luck, cause that sucks.
SOURCE: have NV-GS5 DV Panasonic camera..it is Japanese
ave NV-GS5 DV Panasonic camera..it is Japanese language..i want to change this language to English..kindly help me ..
nadeem [email protected]
