Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washing machine moter
I have a whirlpool 60 hz moter # 3363736, I pulled from a washer to make another tool. I neglected to get the schematics from the machine. Can you tell me by color code the positive negitive and ground, so I can hook it up????? thanks.
amarnaud@mindspring.com
  • Anonymous Feb 24, 2009
    No scematic for hp 1/2 volts 115 amps hz 60 rpm 1725/1140 I am unable to wire it to run as it is thermally protected . it over heats and cuts out . There is a black wire,a white with a black stripe,a brown wire, a blue,a yellow ,and a white wire that goes into a small black box then out . there could be twenty five diferent combinations some for clockwise some counter clockwise . I would be happy just to go any direction without heating up . How do I wire it .
  • ernie_hansen Mar 28, 2009
    I want to use the same motor but could use a schematic diagram to wire it. From my searches it is a single phase, two speed motor used in kenmore washers. It has a centrifical switch and a capacitor with a thermal overload switch. It is also used by Whirlpool and I think it is made by them or some company related to them known as FSP. Any help would be appreciated. Someone must have a diagram of this motor.
    ernie_hansen@prodigy.net
    Scholar:
  • 160 Answers
Green is ground, white is neutral, red/black is usually hot on a 1 phase 110-120v motor. (normal colors are black, white, green).
if three phase, (208-220v), green is ground, white, is neutral, black/red/blue are hot. (only uses 2 of these, so there should only be a total of 4 wires). once you have the wiring connected, turn on the motor, and check the rotation direction it turns. if it turns backwards, reverse the red/black wires, the red/white wires, or the black/white wires.
be sure you look at the data plate on the motor to determine one or three phase motor.
their should be a small diagram of which wire inside go to which other wires inside on a three phase motor and for which voltage, and are usually numbered on the individual wire.
good luck.
Posted on Dec 05, 2008
6ya staff
SOURCE:
Whirlpool duet wfw9450wr00
Michael, I too am looking for the same as you for my Whirlpool 8.5kg WFE1485BD. Similar machine as yours but newer. I need the schematic diagram to see how the door interlock switch works. Your problem sounds like that as well, have you tried manually working the switch with door open and checking with an ohmmeter? Does your machine give a door open warning light? I have pulled my door switch out and disassembled it but can't work out which contacts get switched. Please email me if you find a service schematic and I will do the same: steelwheels7@gmail.com
Mar 09, 2014 | Whirlpool Duet GHW9150P Front Load Washer
How to convert 50 hz waterpump to 60 hz??
you cant but difference between 50/60 hertz should not stop in running does the rest of machine work ok does it wash spin if so I would be lokking for wires of jammed pump ect
Mar 08, 2014 | Samsung Washing Machines
Hitatchi sf p150jj
Some washers can but the speeds will be slow unless it is a digital motor control.
Dec 19, 2013 | Washing Machines
How can i change the power from 110 volt to 127 volt, jamaica is 110
Voltage is not the problem. The issue is a 60 hz machine in a 50 hz country. The fix is to buy a Jamaican washing machine.
Mar 03, 2012 | Daewoo DW500M Top Load Washer
I cleaned the strainer, checked all the hoses, but still got the F-21. Checked the pump no objects inside. Still got the F-21. Checked the pump again and found the impeller does not spin freely. Is this...
I have the same problem: new drain pump, impeller needs to be "kicked" to start reciprocating (which, of course, is not possible once installed). Drain pump is listed as 50 Hz (UK), though I am in US (60 Hz) - could that make any difference?
Apr 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have removed the rear panel of my washing machine to replace the drain hose assembly. I now have questions about where some of the plastic clips to route wiring go. (they fell off during panel...
If you enter your model# at the link provided you will be able to pull up diagrams and illustrations. This type of washer is supposed to have the front housing pulled off to gain acess. The link provided will also have a video that walks you thru the correct procedure for Disassembling a whirlpool style washer
Sep 27, 2010 | Whirlpool LSN1000LW Top Load Washer
Is it possible to take a Whirlpool 3363736 and make a grinder?
I see bench grinders for about ten or twenty dollars at the flea markets all the time. They also have the $$ grinding wheels on them.
May 16, 2009 | Washing Machines
Agitator problem
POST MODEL NUMBER PLEASE
Apr 27, 2009 | Washing Machines
WHIRLPOOL TOP LOADER MODEL GSQ9669LWO
Trick or Treat. You coupler is out and I will supply a link for parts and schematic, please note part 13
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?modelNumber=GSQ9669LW1&productCategoryId=0153200&brandId=1198&modelName=WASHER&diagramPageId=00004&componentDescription=BRAKE, CLUTCH, GEARCASE, MOTOR AND PUMP PARTS&documentId=W0403060&backToLink=Return to Sub Components list
Oct 31, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
425 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
