In the photographs lines and bars are spoiling the images like retrace lines on a TV screen.. It is more in Low light. Lines are white or of various color like red, violet etc.
SOURCE: lines in images
Sent camera to Kodak whch fixed it and sent it back weeks ago. A solution almost a month after the inquiry is too late to be helpful.
SOURCE: screen has lines
Most likely youve damage the lcd screen either by dropping it even though you didnt, but that would be the only cause this problem, line on a lcd screen are usually cause by a broken power current thru screen or a cracked lcd screen maybe it was defective in the first time. I dont know, but line are usually means no power or no information going thru screen.
need to be replaced.
Iām happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
SOURCE: My Kodak EasyShare M753's screen is white with black lines
That must have been caused by a drop and I'm pretty sure your screen is gone. Try to send it back to Kodak they may not charge you if it's not obviously physical damage, if they refuse to give you warranty service there are third party camera repair places but they will definitely charge you.
SOURCE: Vertical lines on screen. Can't see picture at
It sounds like you need a new screen.
Buy one on Ebay for 20 Euro (inclusive of postage)
youtube.com has great videos of how to change a screen.
You will need a tweezers and very small "philips" (cross/plus head) screwdriver.
Make sure the screwdriver has magnets....so that you dont lose some screws....they are tiny.
If you buy a replacement "LCD Screen Display" on Ebay then usually all the tools you need are included. (I just checked).
I also have just replaced my screen....screen was damaged...LCD leaked and lots of vertical lines on a now only WHITE screen.
Camera works fine now.
Check to see if the camera is still working.
Try taking some pictures....and then put the SD-card into your computer to see if the pictures are being taken.
SOURCE: P850
My lens on P850 when I turn it on goes out and then goes back in, I have change the battery, can you assist
