Reasons for Black Screen of ***** and How to Fix it
Hi, This is probably too late but I really hope this can help you or others.
Firstly, we need to know what cause the Red Screen Issue:
A. Your iPhone Device Has A Hardware Problem
B. Your iPhone device has been jailbroken
C. Your iPhone device has a failed software update
Secondly, Here are some common solutions to fix Red Screen of ***** Issue:
A. Perform A Soft Restart on Your iPhone Device
B. Perform A Force Restart on Your iPhone Device
C. Restore Your iPhone's Default Factory Settings
D. Bring Your iPhone into DFU Mode
E. Update Your iPhone to The Latest Software
Thirdly, If the common solutions could not solve your problem. You can try an data recovery software - FoneDog toolkit.
Step 1: Download, install and launch FoneDog Toolkit.
Step 2: Proceed to System Recovery.
Step 3: Review Reminders before The Recovery Process.
Step 4: Download The Firmware.
Step 5: Downloading and Repairing
Step 6: Repair is Complete
More Information you can see: Ways to Fix Red Screen Issue in iPhone Device
The red screen issue in iPhone devices is truly a bothering issue to have since it can stop you from being productive in using the phone or making it fully functional. Through the common solutions we have shared above for fixing such issue, as well as the help of FoneDog toolkit, we hope that the red screen issue in your iPhone has now been fixed.
Hope it can help you!
SOURCE: iphone 3gs on a parrott
First of all, can not guarantee that your iPhone will work with that Handsfree Bluetooth, regardless of what any of it says. The iPhone is manufactured by Apple to work on its own, it is not made to work with any of these 3rd Party products, contact that manufacture for more information.
First thing I would try is on the iPhone go into your Settings > General > Reset > Reset All Settings
(NO YOU WILL NOT LOSE ANY DATA) Once you tap that, it will inform you that it will NOT erase any of your data, simply just resetting the settings, getting rid of any glitches. Test it out after this, if its still an issue, continue to the next step.
Best thing to do, since this mostly sounds like a software issue. Restore the iPhone using iTunes and a computer (Download iTunes here: www.apple.com/itunes ).
-Plug your iPhone into your computer using your USB Cable that you plug into the charger with.
-If possible, plug into the back of your computer if you're using a desktop.
-Open iTunes on your computer, make sure its fully update, a message will pop up telling you it needs to be updated.
-When iTunes is open on your computer, you should see your iPhone listed in the left-hand column beneath Devices
-Click on your iPhone, in the main window of iTunes you should see a Restore button half-way down the page, click that and it will ask you if you're sure.
-Agree to the terms, yes this step is going to erase all your data on your iPhone.
-iTunes does automatically create backups of your iPhone, however these can store corrupted files, and are not best used in a situation like this.
-For further information on BACKING UP your data by syncing, THEN restoring your iPhone, follow this Article: http://support.apple.com/kb/ht3828
SOURCE: my iphone's touch screen won't work after being dropped in water
You may have to get a screen replacement. You can do this yourself if you want to try it and buy the parts. Or take it into a shop, or apple will replace it but most likely charge you way more than any of those options unless its your first replacement.
