I have a HDLCD-3200A model TV
I was told that 480i was standard television quality. That is what my tv is displaying in. I thought this was a high definition TV . How come my TV is not displaying in high definition quality. How do i hook it up. i have component cables and everything but still no hi def picture. I want to connect it to a cable box and dvd player.
Please help.
Thanks
Hi, first of all you need a high definition source. I'm not sure if your cable box is HD but lets take it as an example. The component leads which you are using isn't 'true' HD video quality, what you need is a hdmi cable from your source to your TV.
Your cable box maybe HD with a HDMI output, if it is then you need the lead to come out of the cable box into your tv's HDMI input using a HDMI lead. Then you switch your TV's source to the HDMI input and it then should be producing a HD quality picture, but to truly get the full HD experience you may want to subscripe to a HD channel or purchase a blueray player becasue most cable TV channels are upscaled to HD and the definition is not as good as on a blue ray disc or a true HD channel.
So in conclusion the cable and input you are using is not designed for HD input. I believe your TV is HD, check for HDMI inputs or DVI inputs.
Hope this explains your problem
I have a Sharp dt-100 projector with a Blueray. It is not displaying HD at all. Regular dvd's are blurry as well. Please help. Thanks
Andy
