HP PSC 1402 All-in-One Printer
Want to install printer software
I HAVE (HP PSC 1402 ALL IN ONE PRINTER
THERE R ONE AED IS BLINKING THIS LED IS MESSAGES IS "CHECK PRINT CARTRIDGE ERROR , BUT I N CHANGE MY PRINT CARTRIDGE PLEASE HELP ME WHATS MY PRINTER PROBLEM
Posted on Sep 13, 2009
  • 51 Answers
You can find the software for download from HP's website and then choose your operating system
Posted on Nov 28, 2008
5 Suggested Answers
6ya staff
SOURCE:
jo_chinmay
Chinmay Joshi
  • 148 Answers
SOURCE: hp psc 1402 all in one scanner not scanning
just chek in my computer is that show any scanner last on screen if it is then scan thru that tool if there is no scanner icon avalable then i need to set drvier thru device manager... it's help u
Posted on Jan 09, 2009
acdr
kishor khatri
  • 1913 Answers
SOURCE: please help me to install
hi
downlaod free from here
http://www.printcartridgedirect.net/frames/hp_psc1402_driver.htmand install.
Posted on Jan 17, 2009
Anonymous
  • 813 Answers
SOURCE: lost cd to install printer
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&product=441116
here is link download
Posted on Aug 24, 2008
Michel Smith
  • 1218 Answers
SOURCE: I can't install HP PSC
Following are some of the tips, which you must follow while you are using a printer with Windows 7 system.
Ensure that the cables are properly connected; you need to ensure that your printer is properly connected, and plugged in, and also the cable is accurately connected to the computer as well.
Check the power; make sure that the printer's power is switched on, ensure that all the computer necessary computer components are also turned on.
Make sure that the hardware is properly plugged in, and also turned on. Apply troubleshooting.
A troubleshooter is a tool, which is generated automatically and which can easily fix the problems that occur with your system.
Thus, if you are coming across different issues related to your printer, then you can consult the troubleshooter.
You require driver applications to run your hardware devices.
Make sure that the drivers are not outdated, corrupt, or incompatible, resulting in disrupting the communication between the printer and the computer.
Always make sure that you are making use of the most recent and latest device drivers, and also that are compatible with your system requirements and specifications, as this can be extremely useful in resolving printer issues.
Posted on Dec 01, 2010
My HP PSC 1402 All-In-One printer when plugged in "all lights are on" how do i get it back to normal so i can print again? tnx
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken .
Jun 29, 2011 | Office Equipment & Supplies
1402 Need Reflash
Alot of people are having the same problem with the hp printers i have looked at many printers with this problem and the most i have solved with reinstalling the printer to the computer you can do this by going to tcontroll panel > printers > right click and delete printer
then reinstall the printer using the disk or by clicking add new printer
im sorry but this is all the information i can provide on this problem
Aug 22, 2009 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 1402 all in one scanner not scanning
Jan 09, 2009 | HP PSC 1510 All-In-One InkJet Printer
TO INSTALL PRINTER SOFTWARE
You can download the required software from this below mentioned link:
HP PSC 1402 Compatible software and drivers
Thank you
Nov 28, 2008 | HP Office Equipment & Supplies
Hp printer
Download and install software from HP website here: » Support & Drivers
Nov 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
Give the solution of my HP PSC 1402 All-in-One InkJet Printer Problem
Have you tried to download the driver form HP Support and install it?
And....are you using Vista?
Here is the support page for your printer.
PSC1402 Support
Download the correct driver for your operating system.
Uninstall (delete) the printer and start over. Make sure you disconnect the usb cable before you install the software. Don't plug it in until the software prompts you to.
Nov 04, 2008 | HP PSC 1510 All-In-One InkJet Printer
Lost cd to install printer
You can download the installer form here. Select your operating system from the list.
http://h10025.www1.hp.com/ewfrf/wc/softw...
Install it to your computer after downloading
Aug 24, 2008 | HP PSC 1401 All-In-One Printer
Printer HP PSC 1400 to run with Vista program
You will need to go to the HP support site,
http://welcome.hp.com/country/us/en/support.html
Find your specific printer, and download the driver for Vista. Should not be a problem after that.
» HP PSC 1401 All-in-One
» HP PSC 1402 All-in-One
» HP PSC 1406 All-in-One
» HP PSC 1408 All-in-One
» HP PSC 1410 All-in-One
» HP PSC 1410v All-in-One
» HP PSC 1410xi All-in-One
» HP PSC 1417 All-in-One
Feb 23, 2008 | Office Equipment & Supplies
Hp psc 1210 all in one problem
Hey Neddy I found you on the HP site thius link, it explains how to fix your problem follow this instructions, they are pretty simple and Good luck http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=bpy21098&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Sep 02, 2007 | HP PSC 1210 All-In-One InkJet Printer
1,086 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
