Question about LG 32LG40 32 in. LCD HDTV
Lg dvdcombo region codes
Any help to change from reion one to region four
  • LudwigMartin Apr 22, 2009
    I HAVE FOUND THE SECRET MENU TO CHANGE THE REGION CODE, I DID IT BUT THE DVD DOESN'T PLAY, AFTER LOADING NOTHING HAPPENS, IT'S JUST THE DVD HOME SCREEN ALL THE TIME, AND I TRIED WITH MANY DVD'S.
I have just hacked an LG 32LG4000 combo tv/dvd. To open up the dvd to multi region, turn on the tv & press the menu/set up button. Next, navigate to the lock symbol but do not open the sub menu. Press 0 seven times. Exit out of the menu, and your 'on board' dvd player will play dvd's from any region!
Posted on Dec 30, 2008
  • Anonymous Dec 30, 2008
    Sorry, Re: LG 32LG400 tv/dvd combo please ignore previous advice, it doesn't work!
    This fix definitely does. Press the menu/setup button on the remote & the menu button on the tv simultaneously for 5 seconds. A hidden dvd menu will appear, and you can change your region to worldwide. It may take a 'couple of goes' for the menu to appear but it will come up. So keep trying.
    New Friend:
Can confirm it works, it will take 2/3 goes for the screen to appear and you have to change region to WORLDWIDE.
Posted on Jul 23, 2010
    Novelist:
  • 170 Answers
There may well be a menu option for changing region codes. You want to reset for region 0 (zero) which allows you to play any DVDs. Go through all the set-up options using the original remote. I have changed Phillips and many other DVD units just using the menu. Try set-up menu, then disc menu. It will be at the bottom, probably on the last menu option, under Region. Some website offer region codes also for specific units, but you will have to search.
Posted on Nov 28, 2008
6ya staff
SOURCE:
Lg bp620 , DVD region free codes query
Doesn't work. Press 0 four times did absolutely nothing.
Nov 16, 2012 | LG Electronics Bp620
Plastation 3 wont load games tested blueraydrive in another console and it works everything else works can go on network and internet
It depends on the region that it is playable. I believe the reion code is the problem why it is not playing.
Or there are lots of scatches that the unit is unable to read
Nov 22, 2010 | Sony Playstation 3 (PS3) Console
Changing region code to all on a LG DV550 DVD player?
icon_minipost.gifRegion code hack posted by hackaroto, December 27 2010:
1. Switch off the DVD player in to Stand By mode
2. Open the DVD tray using the remote control
3. Press "pause" in the remote
4. Enter 0, 0, 0, 0 (zero 4 times)
5. The display should indicate the regional code set in the DVD and prompts for the new regional code.
6. Enter the new regional code
7. Press Pause to exit the setup
8. Switch off the DVD using the remote and wait for a while before switching it on again.
works for other LG DV55X players
Aug 03, 2010 | LG Televison & Video
I have a LG HT554PH home cinema and would like a region code to enable it to play region 1 dvds. i have just paid £5 from a website and it is no use my dvd player wasnt on the list. there is a reion...
Hi
To make the player as region free, switch on the LG HT554 Player. Push the eject button to open the tray. Now, press “0” on your player 4 times or until the region code settings shows up on your player. It will show the current region code and will then ask for new region code. Press “0” on your remote to set it as a new region code(0=All Regions). Press Enter key on remote, now restart your player and check the player by playing the DVD’s. It should be region free now.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Jul 23, 2010 | Audio Players & Recorders
Just bought LG HT554 DVD Receiver, was told it was
This one worked for my HT lg 554:
Power On
Open the tray
Push 0 four times
Push Pause button
Though, I didnt do the last step, since the code edition appear before.
Mar 03, 2010 | LG Electronic LRA516 DVD Recorder
How to change region code on an LG DVD recoder, model #DR386D so it can play region 2 as well as region 4.
some lg units have a region menu if you have the drawer open and press zero 5 - 6 times. then simply choose reion code. this doesnt work on all lg units.
Jul 03, 2009 | Televison & Video
Code region
power on the dvd
let it load and show no disc
open tray and enter '0' four times
region edit and region code appears with the default code
press 0 for region free and enter
region code should be 0
press pause on remote
power off and on again
Jan 03, 2009 | Televison & Video
Regional Code
3602
1. Power on,
2. Press "Pause" ||
3. Enter "314159"
4. Press "0" (for region free)
5. Press "Enter"
... the 0 replaces the previous region number in the second line.
6. Press "Pause" ||
7. Power off.
Or
With the unit in DVD mode and the drawer open, key in "0" four times. A two line menu appears with "Edit Region:_" and "Region Code:x". Key in the required region (presumably 0) and press enter. Power off
HT762tz:
http://www.videohelp.com/dvdhacks/lg-ht762tz/9060
May 16, 2008 | Televison & Video
Region codes
No, you can't change the region codes. If at all possible I would take it back to the store and slap the salesperson!!!
Failing that, all games are not region coded, so you can play aus games on that machine. It seems the only thing it won't play is some blueray discs.
Dec 25, 2007 | Sony Playstation 3 (PS3) Console
LG 32LG40 32 in. LCD HDTV Logo
837 people viewed this question
Ekse
RONALD CARTER JR
