Question about Toshiba 37AV502U 37 in. LCD HDTV
I have a toshiba 37av502u when i turn it on there is a black screen the green power light is on just no pic
At first it would work for a bit then go black the it would work again then go black now it just always black
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 96 Answers
Have some to check it for you you might have a power supply problem
Posted on Jun 04, 2012
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 1077 Answers
SOURCE: TOSHIBA FLAT SCREEN TV has black screen but power light is on!?
Try resetting the TV by leaving it unplugged for an hour.
Plug it back in and check to see if it works normally.
If that doesn't work, rule out the Directv box by pressing the reset button near the access card. The box could be putting out a signal that doesn't have video or audio.
If everything fails, have the tech man come back to check everything that he did before you use the warranty on the TV.
Posted on Feb 20, 2009
tvservice306
tvservice306
  • 458 Answers
SOURCE: Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Posted on Oct 02, 2009
raymond marundan
  • 293 Answers
SOURCE: Toshiba 37AV502U Sounds keep going up all the
Deffective system ic.For repair and replace system ic.
Posted on Jul 04, 2011
Toshiba 37 inch flat screen 37AV502U keep turning itself on then off randomly. Any ideas what it could be?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Apr 20, 2016 | Toshiba Televison & Video
Black screen and no sound
The problem is most likely the the screws are loose on the inverter boards. The screws must be tighted as they provide the ground to the inverter bds. The inverter boards are undet the shields on both sides of the unit after pulling the back cover. One way to make sure that you are losing back lights and not video is when your picture goes black, shine a flash light on the screen at an angle and will see the video is still there. This mean the back lights are out. If you do not see the video it may be another problem
Nov 02, 2012 | Toshiba 37AV502U 37 in. LCD HDTV
My toshiba 32av500u has no picture completely blak only power little lit in front . turns on green no kind of sound
I have the same problem with the black screen and no sound. Also the green light turns on and off while hitting the power button. Although if i turn it on then off multiple times it eventually turns on and works perfect... Could you do the same thing before it finally quit all together or did yours just happen over night?
-Kenny
Aug 04, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
Black Screen on Toshiba Satellite A105 S1014
Blown or damaged graphics chip on motherboard, would take to specialist repair shop
Feb 09, 2010 | Computers & Internet
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
Toshiba Satellite A135-S2376, black screen problem
first instinct u cooked sumthing
second try unpluging and removing both batterys ur nicad and the internal lithium 1
this shuld force bios 2 reset
if u cannot locate the internal battery un plug power and batt
w8 aprox 3days the internal clock will drain it 4 u
Apr 05, 2008 | Acer Aspire 5100 Notebook
Black screen
how can u fix this black screen? the green power light is on, shows vista for a bit then turns black and stays black. any solutions or do i have to send it back?
Apr 03, 2008 | Microsoft HannsG HU171D 17" LCD Monitor
Toshiba 37AV502U 37 in. LCD HDTV Logo
230 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
