Question about HP Pavilion dv6000z Notebook
Unable to start laptop
Hi der! i ve hp pavillion dv5-1102tu laptop . m unable to start it ... i tried to start it normally -it didn work, den i tried using start up repair , even it didn help... please help me to start it without loseing any data.... need it urgently!!!!!
  • George Duck
    George Duck Mar 10, 2015
    I realize this is was 6 1/2 years ago, but just in case you are still waiting for an answer, here goes. I am assuming that when you start up the computer,. NOTHING happens? No light on the front, nothing on the screen, etc? Assuming you have checked to make sure that your computer box AND the monitor are both TURNED ON, please take the thing down to a computer shop and have them test the power supply. It may have went t i t s up. But IF you are getting some messages on the screen, assuming that you might HAVE POWER - what kind of messages are coming up on the screen? This is important info to know, so someone can help you. Otherwise it's like shooting in the dark. (I've done that before, but it lacks the visual stimuli that leaving the lights on has).... ;),
    Scholar:
  • 69 Answers
I understand the urgency and also the importance of data stored in the laptop.
As the laptop is unable to start in normal mode let us try in safe mode.
Follow the steps below:
1. Turn the laptop off completely.
2. Press the power on button to turn it on and at the same time simultaneously keep tapping ' F8 ' key on key pad until you see a advanced boot options screen.
3. Select 'safe mode' and hit enter.
Thank you.
Posted on Nov 28, 2008
6ya staff
SOURCE:
Ik heb een Power safe TR36 en op zoek naar de handleiding. Kan iemand me hier aan helpen aub? petieske@hotmail.com
Bedienungsanleitung Bitte sorgf?ltig lesen und an einem sicheren Ort aufbewahren
  1. Erstmaliges ?ffnen • Taste S dr?cken: Gelbe LED leuchtet auf. • Taste E dr?cken: Gr?ne LED leuchtet f?r 5 Sekunden auf - innerhalb dieser Zeit den Knauf nach rechts drehen und den Tresor ?ffnen.
  2. Stromversorgung • Es werden 4 St?ck 1,5V-Monozellen/D/R20 bzw. entsprechende Akkus ben?tigt. • Das Aufleuchten der roten LED signalisiert eine nicht mehr ausreichende Batteriespannung. Der Batteriesatz sollte dann umgehend komplett ausgewechselt werden. • Batteriewechsel: Abdeckung vom Batteriefach auf der T?r-Innenseite in Pfeilrichtung abschieben. Batteriesatz samt wei?er Kunststoffh?lse entnehmen. Neue Batterien gem. Abb. in die H?lse einstecken
  3. Erste Geheimnummer programmieren
• Bei ge?ffneter T?r Taste S dr?cken: Gelbe LED leuchtet auf. • Rote Taste auf der T?r-Innenseite dr?cken und wieder loslassen, anschlie?end eine beliebige Ziffernfolge eingeben. Mehrfachbelegung von Ziffern ist m?glich. Der Geheimcode kann aus 3 bis 8 Stellen bestehen. Geheimcode vor der Programmierung festlegen und gut einpr?gen. • Taste E dr?cken um den Programmiervorgang abzuschlie?en: die gelbe LED erlischt. Die Geheimnummer bleibt auch bei Batterieausfall gespeichert. • ?nderungen in gleicher Weise programmieren.
  1. Zweite Geheimnummer programmieren • Wie unter 3. beschrieben. Jedoch mu? vor der roten Taste die O-Taste zweimal bet?tigt werden.
  2. Verriegeln • T?r schlie?en und den Knauf bis zum Anschlag nach links drehen.
  3. ?ffnen • Taste S dr?cken: gelbe LED leuchtet auf. • Geheimnummer eingeben. • Taste E dr?cken: gr?ne LED leuchtet f?r 5 Sekunden auf - innerhalb dieser Zeit den Knauf nach rechts drehen und den Tresor ?ffnen.
  4. Falscher Geheimcode wurde eingegeben • Gelbe LED leuchet. • ?fmungsvorgang gem. Punkt 6 wiederholen.
  5. Ausgangszustand wiederherstellen • Tresor ?ffnen. • Taste £ dr?cken: gelbe LED leuchtet auf. • Taste 1 zweimal drucken. • Rote Taste auf der T?r-Innenseite dr?cken. • Nach Ert?nen von zwei langen Quittiert?nen werden beide Geheimnummern gel?scht -gelbe LED leuchtet auf. • Die gelbe LED erlischt nach ca. 30 Sekunden, zwei kurze Quittiert?ne signalisieren die Erreichung des Ausgangszustandes.
  6. Schl?sselbetrieb • Der Tresor l??t sich mit den mitgelieferten Schl?sseln ?ffnen, falls die Elektronik aufgrund verbrauchter Batterien nicht mehr reagiert, die Geheimnummern vergessen wurden oder der Betrieb ohne Elektronik-Schlo? gew?nscht wird. • F?r den Schl?sselbetrieb mu? die Abdeckung unter dem Typenschild mit einem Mini-Schraubendreher oder einem ?hnlichen Werkzeug vorsichtig abgenommen werden. • Schl?ssel an einem sicheren Ort - jedoch nie im Tresor - aufbewahren. • Die Geheimnummern bleiben gespeichert.
Jan 02, 2015 | Home Security
Das komplette Oberteil wackelt beim Ruehren hin und her. Was kann ich machen. Der Bolzen der das Oberteil haelt war schon mal komplett raus gefallen
Sie mussen sicherstellen, dass der Gelenkbolzen ist dicht , schalten Maschine komplett auf den Kopf und ziehen Sie die Schlitzschraube im Inneren des Sockels . Wenn das nicht hilft , mussen Sie uberprufen, dass der Verriegelungshebel richtig in den Schlitz eingreift . Sie mussen moglicherweise " LEICHT " -Datei in den Schlitz im Sockel , die den Hebel in Eingriff steht. Wenn Sie mit der Datei verruckt konnten Sie den Steckplatz zerstoren.
Sep 13, 2014 | KitchenAid 5ksm150pseer Artisan Red For...
WAS IST HPSU-0004 WIE KANN ICH ES INSTALLIEREN
Hi!
Erstens verzeih mir bitte wegen Schreibfehler. Meine Muttersprache ist nicht Deutsch.
Jetzt zur loesung:
1. Auf der support-seite von HP suche und lade herunter die (sehr grosse) Datei welche die FULL drivers und applications fuer dein Drucker beinhaltet;
2. Starte die gerade heruntergeladene Datei bis zum Punkt wo es anbietet die software zu installieren;
3. Click NICHT auf "Install", sonder verlasse den Installer (z.B cancel). Am diesem zeitpunkt haben wir auf die festplatte alle spaeter notwendige Dateien;
4. Jetzt finde den Ordner wo alle diese Dateien gespeichert wurden. In diesem Ordner soll der Ordner "setup\hpupdate" sein. (der Ordner musste in TMP oder TEMP sein - am besten verwende die option SUCHEN;
5. Nur nachdem du den Ordner gefunden hast koennen wir fortsetzen:
6. In Windows Systemsteuerung, programme entfernen, werden wir das programm"HP Update" entfernen. Kann sein dass mache Fehlermeldungen dabei entstehen, aber das ist normal unter diese Umstaenden
7. Jetzt gehen wir zurueck zu dem Ordner den wir bei Schritt 4 gefunden haben. (setup\hpupdate), und doppleclick die einzige *.msi Datei die es dort gibt. Dadurch wird die HP Update Utility neu und richtig installiert;
8. Wenn die Installation (Schritt 7 ) vollendet ist, kann die HP-Update utility ausgefuhrt sein, um updates fuer alle Deine HP anwendungen zu erhalten.
Hoffe es war hilfreich
Beste Gruesse!
Aug 20, 2011 | HP Photosmart C6180 All-In-One InkJet...
Hallo wie kann man die uhr bedienen
  • Ich nehme an, Sie haben die Cobra 2000 als das ist die einzige Cobra-Modell mit einer Uhr auf.
Um die Uhr auf sie diesen Schritten folgen -
Time Set - 3 Switches (zur Zeit eingestellt) Dynaalert - 3 Switches (zur Alarm-und Radio) Counter / Clock - 3 Switches (zur Anzeige auswählen)
TIME SET Time Set Switch - Drücken Sie diesen Schalter mit Stunden-Schalter oder Minute-Schalter zur Einstellung der richtigen Zeit.
Stunden-Switch - Durch Drücken dieser Taste gleichzeitig mit dem Schalter auf die richtige Stunde Einstellung zu erhalten.
Minute Switch - Durch Drücken dieser Taste gleichzeitig mit der Zeit den Schalter auf den richtigen Minuten.
Dynaalert (Wecker) - Depressing thr Schalter auf den ersten und dann über die Zeit eingestellt VERFAHREN (nicht in Betrieb) wird Ihr Wecker gestellt. Nach dem Alarm auslösen Schalter ist so um die Uhr funktioniert normal.
Alarm Switch - Mit diesem Schalter Ursache des Alarms zu einer vorgewählten Zeit ertönt. Release-Schalter, um den Alarm abzuschalten. Alarm wird auch gehen automatisch nach 1 Minute, wenn Sie nicht mit dem Schalter Freigabe wählen.
Radio einschalten - Drücken des Funkschalter wird das Radio dazu führen, dass wiederum auf der vorgewählten Zeit. Drücken Sie Schalter auf Radio auszuschalten.
Counter / Tine - Ist dieser Schalter bewirkt, dass der Empfänger Frequenz angezeigt, um in den Empfangsmodus und die Sendefrequenz im Sendebetrieb gefunden werden.
Auto Switch - Ist dieser Schalter bewirkt, dass die Zeit gefunden, um in den Empfangsmodus und die Sendefrequenz im Sendebetrieb gefunden werden.
Zeit-Schalter - Mit diesem Schalter Ursache der Zeit kontinuierlich angezeigt werden.
Tony
Apr 23, 2011 | Cobra Radio Communications
USB ports won't work on HP Pavilion ZV6008CL
Try updating BIOS and check and also try the reinstalling the USB roots hubs again
Jul 06, 2009 | HP Pavillion ZV6000 Notebook
HP Pavillion Entertainment PC screen blank, power lights on
try this put off the laptop and remove the battery and the power cable and then hold the power button from 30-60 seconds then put back the power cable(without battery) and switch it on it should work then shutdown and put battery pack in
Apr 05, 2009 | HP Pavilion dv9000z Notebook
HP laptop speakers not working
hi,
whenever you put in the head phones the speaker will stop working and when you take the headphones out they will start working again this is their normal behaviour.
Further Queries are welcome
Feb 21, 2009 | Acer Aspire 3680 Laptop
HP Pavilion dv6000z Notebook Logo
1,068 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
