My Comand screen does not turn on and off when i turn the key anymore. When i turn it on manually (PWR Button) it stays on the MB logo. I checked all related fuses and they are good. Any suggestions?
SOURCE: Comand aps for mercedes C (w203) doesn´t work any more
Hi. I´m also from Portugal and can solve situation. Please send me mail to [email protected] Cumprimentos
SOURCE: Good eve. i have a mb c180 2000 model. The manual
you are using the valet key (it has a flute down the centre)try using another key....
SOURCE: Where can I get an instruction manual for a Mec
Either from the Mercedes Dealer or you can see if anyone is selling one online at an auction site. Best place might be the dealer. I dont think they are too expensive.
SOURCE: Major issue with 2006 Mercedes
Radio should have shut off automatically after 30 mins. have you an
owner's manual? there is a 'mute' button on the radio. the 05 slk did
not have a radio code to reenable it after battery replacement. my old
05 had some 'comand' quirks like could not find sat radio sometimes.
when u get a new battery, it might magically work.
Good luck.
SOURCE: My comand system on my 2006 R320 is frozen on the
You can try with disconnected battery ground cable, battery is fitted under front right side seat, whether it's left hand drive or right hand drive, if not work have a good look is there any switch stuck on command if one switch stuck it won't be operating, if one stuck after press you have to pull it back then it will work, is this information helped you
