SOURCE: LG W1952T LCD monitor power save mode during bootup?
called customer service - see other post for details
SOURCE: The power button on my LG W1934S monitor just
try this....
remove the vga cable at the back of your monitor or at the other one in your cpu..
get it?? the one that connect the cpu and the monitor..
then try to turn on your monitor if there is a message says like this " no signal output" or no video output"..
it means your monitor is ok and you have a problem in your cpu...
sometimes that is the problem....
SOURCE: LG monitor not working.
More likely to have failed capacitors in the power supply section, that will be the first place to check. Please see the pictures here so you know what to look for inside, post back what you find so we can guide you further and it will help other people also.
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Notes: I will assume you have already try it on another PC and it still does not work.
SOURCE: LG w1934s lcd monitor's power led and display on-off blink
check to see if any electrolytic capacitors on the power supply are bulged at the top, if they are replace them
SOURCE: i have lg lcd w1934s
Look for bad caps as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/LG%20W1934S/
You should replace them in a set.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
