The motor does not respond when the trigger is pulled-- I just replaced the cord and trigger ( switch ) they are both good -- a simple voltage indicator tells me that the electricity is getting to the motor-- but there is no response
SOURCE: Delta 36-075 miter saw. Motor ok, but blade will not spin
It sounds as though one or both of the items are stripped. They mesh to drive the blade so I would not take a chance on just replacing just one. Also when you look at this you might also want to look at replacing the bearings and brushes. Make sure you clean out the gear housing or you will have immediate problems again. Also check where you buy these parts for their recommendation on the grease that needs to be used.
SOURCE: where is the lock button for the skill saw
I can't seem to access the parts view for your model, because of its age.
But I'm thinking skil probably hasn't changed things all that much.
Take a look at the 5450 and see if this doesn't help any...click here ...and scroll to page 7.
SOURCE: Makita circular saw 5007n, it will only run when
Great!! Could you please rate my solution as a "problem solved"?
I would greatly appreciate it.
SOURCE: My Skil 5250 Circular Saw does not turn on
If you are pretty handy you can fix it your self. The part you will be looking for will look like this ( $8.00 PART) Look below for a place to buy it.
The diagram is here
Testimonial: "Thanks. I ordered the part. Let's hope that is it."
SOURCE: sparking at the carbon brush of circular saw every switched on.
the armature is shorting across the commutator bars and a new saw will be cheaper than a new armature
