LG LHD659EBL Dehumidifier Logo
A
Anonymous Posted on Jun 04, 2012
LG LDH659EBL Dehumidifier is not working. I have no indicator lights at all. Power is fine from source, temp is 68. Cleaned filter, reset bucket, still no indicators of power to unit.
Has been working right along for 2 years. Last emptied 24 hours ago.
5 Related Answers
Anonymous
  • Posted on Oct 05, 2008
SOURCE: LG dehumidifier
I Have an LG Dehumidifier and water has leaked out to the basement floor, it has a hose that drains into the floor
Anonymous
  • Posted on May 02, 2009
SOURCE: Dehumidifier Error?
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
tbreeze47
Tom Carson
  • 3083 Answers
  • Posted on Sep 13, 2010
SOURCE: My LG dehumidifier tries to
Here is a manual for your machine, in case you don't have one:
http://homeappliance.manualsonline.com/manuals/mfg/lg/lg_dehumidifier.html
You have to join and log in to the following site, but they claim to have 2 answers:
http://www.maybenow.com/LHD65EBL-Code-CH-01-q23864244
Here's what one person said about the code on webogdery.com:
Unit keeps saying bucket full with nothing in it and it will have a CH 01 code come up on the display. NO reference to it in manual. Call customer NO service and they say to take it to a repair shop 1 1/2 hour drive away. I would not recomend this unit to anyone unless you like to keep buying new ones every year or so.
Not good news, but someone said the unit has a 5 year warranty, so you might check into that.
Another person said check the sensors:
--Shoddy craftsmanship:
1. The sensor that stops the unit when the water reservoir is removed is flimsy, often it does not detect that the reservoir is inserted back, one has to fiddle with the reservoir till the sensor finally "catches on", but then every now and then the mechanism will lock and will be unable to detect that the reservoir is full, resulting in a water spill.
It doesn't seem like anyone has figured out this code, but it has to be a sensor, or bad part, if you can just figure it out.
Good luck, hope some of this helps, and thanks for using FixYa.
Anonymous
  • 43501 Answers
  • Posted on Sep 16, 2010
SOURCE: Dehumidifier shuts off with a bucket full error
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Anonymous
  • 63 Answers
  • Posted on Feb 25, 2011
SOURCE: My new LG "ld450eal" DeHumidifier
The switch that says 'Bucket is full' is not adjusted properly.
It will need to be adjusted, normally a screw driver or pliers,
so that when its empty the switch is not made or the contacts
are open.
If it is in adjustment properly, then the switch is bad and needs
replacing.
Before you replace it, check to make sure the wires leading to it
are not touching, it may be sending a signal meaning 'full' by
electricaly touching each other at the switch.
Why does the power light on my dehumidifier flash quickly?
without the model number I cant be 100% sure , but due to your description of the last thing u did , Id say the light is flashing indicating that the water catch bucket is not installed correctly back as it was before , most units have a safety that wont allow a unit to operate unless the water catch bucket is installed and M/T as this would allow it to dump water to the floor if it were not
Lg dehumidiffier will not start bucket is empty light says otherwise
We had a similar situation and the problem was solved when we removed and cleaned the filter which is accessible once the bucket is removed in the front (pull it down and out). Ours was very dirty and it sits between the humidity control dial and what we believe to be a sensor. Once cleaned, the compressor engaged immediately.
Have a year old lg dehumidifier and a code of 01 appears in the window and will not start.
The error Code 01 indicates that either the air intake filter is dirty and needs to be removed and cleaned and/or the water collection bucket is not installed properly. Turn the unit OFF & unplug it, before attempting any service work.
Hope this helped you & thanks for choosing FixYa.
Our DeLonghi condensation removal system no longer removes moisture; it appears to run fine; the lights indicate all systems are on. I have cleaned the filter; cleaned the tube; disconnected the tube; set...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
6helpful
5answers
Error message CH 24. Any ideas? I have the LD651EBL dehumidifier.
We;ve managed to clear this error, at least for the last 5 days. Remove the bucket, and reach up behind the front panel where there is a filter- ours was covered in dust. After cleaning this off, and resetting the machine (by pulling the electric plug out and re-inserting), the error went away.
Your mileage may vary.
My dehumidifier is getting power...the green power light is on as well as a red light underneath it. It was running and then stopped, with these 2 lights on. I cleaned the filter but not sure what else...
heatman101
Whirlpool gold dehumidifier, fan is running, but not collecting water. It's in a bathroom, and the temp doesn't get below 60. filter was very dirty and the inside as well, from not cleaning the filter....
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
5helpful
Dehumidifier runs but does not collect water
I have dehumidifier Whirlpoot Gold Model #39R171E Serial #H/XE11M1K 6203A it was working fine last year, but this year it is not collecting any water, it is running for day. I opened it, cleaned the filter (which was mostly clean) & it still has not water in bucket. What is wrong & is it possible to fix it by myself.
Top LG Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
