Thats all that happens
Canon printer lights blinking error is a common error. Every printer has a flashing light facility to portray its functionality. With Canon printers, you have green and orange flashing lights that give insights into any existing issues.
What Does Orange Light Flashing Mean?
It means there is a problem with the printer.
Solution:
Turn off the printer and disconnect the cord from the printer. Let it rest for some time and thereafter, refasten the cable and switch it on.
What is problem please explain
SOURCE: Canon iP1800 printer,flashing orange light under the green 'on'
Orange light is flashing 7 times and I get msgs that say cartridge not installed properly and cartridge cannot be recognized. I have refilled my cartridges more than once it worked fine for awhile. This is what Canon said.
Subject: Re: Response from Canon - SWSS Web Escalation (KMM10132386V40822L0KM)
> Dear Mike M:
> Thank you for your reply.
> We appreciate your response with the information for your iP1800
> printer.
> The ink cartridges are not designed to be refilled, and this would
> indicate the cause for the issue you are having. each cartridge
> maintain track of the amount of ink used in order to provide status
> information on the level of the ink in the cartridge. Wen refilling an
> ink cartridge, the status information is not updated, and will cause an
> issue such as this.
> The refilled ink cartridges should be replaced with new Canon ink
> cartridges and the printer will resume printing and working properly.
SOURCE: hi, i have canon bjc 3000 printer, and it has
4 times says the ink is empty or not installed.
It has a sensor that checks the ink tanks, if ink is full you may have a bad sensor, or a paper scrap covering.
SOURCE: My canon ip1880 printer orange light flashing 7 times.
1. Press power button while plug in the power cord – green lamp.
2. While hold the power button press resume button twice – orange blink and return to green.
3. Release the power button, Then the PC will recognize new printer install.
4. You need the software for permanent reset.
5. Run the software and select printer port.
6. Then select Set Destination
7. Click MAIN and PLATEN button to reset waste ink counter to zero.
8. Finally test print by click TEST PATTERN button.
SOURCE: i have a canon bjc 3000 printer and cannot
Four orange flashes means the cartridge is out of ink. The ink cartridge itself is the BC-33, and it contains four ink tanks, BCI-3B, BCI-3C, BCI-3M, and BCI-3Y. If the printer had been working properly up until this point, check each of the ink tanks (they unlatch and come out of the cartridge) and replace just the empty one(s). If all the tanks have ink in them, it indicates the cartridge itself is bad, and you will have to replace the entire cartridge.
SOURCE: When I turn on my Canon iP3000 printer the power
Hello try
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
