Mashine starts to spin after about 3 revolutions starts making a grinding noise and throws the belt off
SOURCE: Washer agitates, but makes horrible grinding noise. Spins okay.
thanks for posting problem solve :0)
SOURCE: loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
SOURCE: kenmore frontloader washing machine making roaring
Your rear bearing is bad. Check warranty to see if rear tub is still covered.
SOURCE: Indesit wil103 makes LOUD banging noise on spin cycle
The two dampers that fix to the outer drum casing have plastic bushes that can fall out. Check the floor under the machine, They are easy to replace just click in place.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
