When I turn on my Air conditioner. It blows perfectly fine, but somewhere along the line while im driving the vehicle, the front air vents will stop blowing air out of them. I can still hear the AC running and the back vents blow out cold air as well but the front vents do not blow anything out. I can turn off the ac and turn it on again and the ac will blow cold ac again but will stop blowing within minutes. Can anyone help?
SOURCE: AC blows hot air but AC compressor works
if the compressor works and your freon is charged it may be the blower flapper door....disconnect battery for 10 minutes and then re-connect to reset the electronics that control the flapper
SOURCE: ac compressor cuts on and off and no cool air blows out .
Too many reasons why but it probably needs to go in for repair. compressors will cycle on and off if the system is under or over filled. If there is a flow restriction, a collapsed high pressure hose, clog somewhere in the system(some vehicle owners put sealant or refrigerant with sealant in it) bad idea. Good luck.
SOURCE: ac problem with 1999 mercury sable
most likely a broken blend door or blend door motor, the dash has to come out to replace this.hope this helps and good luck.
SOURCE: 2000 Mercury Grand Marquis will only blow hot air when ac is on
needs re-gassing because one line should be hot (feed) and the return cold , This is a specialist job do not attempt to do it yourself because its extremely dangerous with very high pressures involved
I have the same problem with my 2005 Mercury Mountaineer AWD Premier, except when I turn the fan on higher it sounds like it is blowing very hard but a door or something wont allow the air to come out..Sound is coming from the passenger side inside the dash..sometimes it blows so cold it looks like snow is coming out...lol..but after about 20 - 40 min then is starts acting up again as you stated..If I discover my problem I will let you know.
