Question about Haier Freezer HUF168PA 16.8 Cu. Ft. Upright Freezer
New freezer has bad door seal
My freezer is new and the seal around the door isnt working right. its an upright haier freezer. It doesnt reach the freezer at the door hinges and is worped, its will seal at the corners but not in a spot about a foot in between the corners. should i get a new seal or is there a trick. its new i shouldnt be replacing stuff already.
    President:
  • 1,462 Answers
It often works to warm the seal with a hairdryer and reshape it
Posted on Nov 29, 2008
6ya staff
SOURCE:
Have a upright freezer and the meat on the top shelf is thawed out but the rest of the food on the lower shelves are frozen. Is it a vent problem
Either the door seal is bad or the freezer has a refrigerant leak or a bad compressor. Best to have an appliance tech check it. It won't take him long to locate the issue.
Nov 04, 2017 | Freezers
What is the orange light for at the top of my freezer
Your freezer seals on door are bad causing it to ice up and the light is telling you to defrost,these models have a design flaw that causes this,seals around door have to be replaced to fix.Call your local appliance company and see if they can order you some new seals.
Oct 27, 2012 | Frigidaire 20.3 cu. ft. Upright Freezer...
Things don't freeze on the top shelf right hand side of the door. Also have small amount of water that drips after freezer is opened. This is a manual defrost freezer 20 cu foot freezer
I would suspect the door seal is not making contact or has some defect in it. And that defect is probably in the top right corner of the door. If you have a thermomiter, wait until the compressor kicks in and then slowly run it around the door seal. There should be some area that is colder than the rest. If I am right, then you will need to replace the seal.
Jun 15, 2011 | Maytag 20 cu. ft. Upright Freezer MQU2056B
I have ice buildup in the lower right hand side of the freezer in the back behind the baskets
Haier are a bad brand, the unit has cooling fin frost up and will not allow air to pass through the cooling plates, defrost the unit for 2 days with door open and restart, if all good after that, keep doing it, if not, its lost gas and needs the bin. Quality items deliver lengthy trouble free operation, sorry but I put Haier in the Daewoo class, Kelvinator or Westinghouse next time, its worth that little extra. Regards Russ
Jun 11, 2011 | Haier Freezer HUF168PA 16.8 Cu. Ft....
Buzzer is going off and the door wont close and everything is melting
The air leaks through the door making the things melting inside. Please fix the immediately. Usually the problem is on door seal or hinges .
Jan 09, 2011 | Haier 20.5 cu. ft. / 580 liter Upright...
I have this freezer and it is forming ice on and around the door and won't stop running. I've checked to make sure the door is closed and sealed and it is. What can be the problem?
Does your freezer seem to be reaching around zero degrees. Second does your freezer have its condensing coil under it or on the back and is it clean. If the coils are not clean it can not disapate its heat effectively and will continue to run. If the coils are clean and the door seal is in good shape doesnt have to be perfect your unit may be low on freon. When a unit first gets low it will run all the time and actually get colder for a while then it will start loosing its ability to cool at all. The ice around the door can be caused because of air leaking in or just excess moisture in the cabinet due to a lot of new items added. I hope this helps
Sep 18, 2010 | Frigidaire 16.7 cu. ft. / 473 liter...
Freezer seal isn't gripping properly
in that case. you may have to consult your problem to the store where you bought that freezer. so they have to fix your problem
Jun 21, 2010 | Freezers
I have an upright freezer and replaced the rubber gasket around the door. It is not sealing correctly and ice is building up and also, water is leaking from the bottom of the door. It is a Fridigaire...
ice on top of freezer door they came out with a fix but does not work two vent holes on bottom of door seal mthem off with silicone moisture getting in if that don't work you need to take liner off and spray foam the liner cavities
Jun 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
Mar 27, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Haier Freezer HUF168PA 16.8 Cu. Ft. Upright Freezer Logo
537 people viewed this question
Top Haier Freezers Experts
Marvin
Marvin
Dennis Boxerman
Are you a Haier Freezer Expert? Answer questions, earn points and help others
