Washing Machines Logo
stephanie cloutier Posted on Jun 06, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clogged washer filter - Washing Machines
Shehu Pro
Level 3:
  • Master 1,284 Answers
  • Posted on Jun 06, 2012
Shehu Pro
Master
Level 3:
Answers
1284
Questions
Helped
334456
Points
3802
Hi, this is a common situation that can be fixed yourself. There is a small dome shaped screen in the threaded inlet that the hose couples to. This screen gets clogged up with sediment from the water over time and needs to be rinsed out or replaced,if damaged. They can be purchased at the Hardware Store. If you can't dislodge it with your finger,bend the tip of a straight pin or needle,hold it with pliers and snag the screen,give a little pull. Put the screen back in,making sure it is seated straight.
Thank you.
2answers
Not draining. checked filter. Drain motor runs and fins are spinning
The drain pump can be running, but if the drain filter or hose is clogged, the washer won't drain. Check these first.
I have a whirlpool duet front load washer. the spin cycle did not complete and their's water still left inside. i've tried to shut off the washer and restart it, it will spin once and then stop...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
2helpful
My HE2 washer will not continue on to the drain and spin cycle.
Hi
Daniel
2helpful
We have a LG washer, model wm2487hwm, seems like it is not spinning oiut the water like it used to, clothes seem to be wetter than previously, whats the problem?
Hi
Daniel
The washer pauses mid-cycle. The pump filter is not clogged. After watching the GE video on how to unclog the pump filter, it said if the pump filter was not clogged there may be an imbalance problem. ...
Make sure that your cold water side of the water valve on the back of the unit is no clogged. Mid cycle is usually when the rinse cycle begins and that usually only uses cold water.
Water won't drain from the tub, think the hose may be clogged. Is there any way to clean the hose without completely dismantling the machine? It does spin but the water won't completely drain out. We...
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Good luck.
I have an error code of nd on my washer
If your washer is beeping, and the display is flashing "Nd", your debris filter may be clogged. To check for a clogged debris filter, goto back of machine, look for little door at bottom remove cover and remove filter and clean
Water leaking from bottom, lots of suds.
Hi
Thanks for using FixYa. This may happen due one or more than one of these issues with your washer--
Probably there is something(coins, socks, dirt, debris, etc) stuck inside the drain filter of your washer. You'll need to check the drain filter. To access the drain filter. To check the drain pump follow these steps:
Unplug the washer to completely disconnect electrical power.Remove the bottom front service panel as shown in the first image below.
Also check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
This issue can also be due to clogged drain pump or drain filter, due to which the hose have developed leak. This will cause suds
Please rate the solution if you find it useful and helpful.
Thanks
Rylee
3helpful
2answers
Wht does the code OE Mean I can't find my manual for my LG 2077 washer
HI. this code represents a drainage problem. The drain hose may be bent or clogged with debris or, it may be a clogged drain filter as well. I recommend cleaning and straightening the drain hose and i would also clean the drain filter. this should fix the issues you are having with this washer.
please rate and god bless.
Kenmore elite washerabout 5yrs old model 170 ser# CK4512109. washer panel reading "Ld" washer came with house no manual
Means long drain.
Either pump is plugged, drain is clogged or filter is clogged.
Please check filter, drain and than pump.
Top Washing Machines Experts
john h
