My Astar TV has problems turning on for whatever reason. The green light will come on but the picture however will not. To get the TV to turn on I have to turn the main power off and on several times.
OK HERE'S THE DEAL WITH THE ASTAR YOU ALL SPEAK OF THE PERSON FROM SOLUTION 3 IS RIGHT IT'S A POWER SUPPLY ISSUE WE'VE GOT 130 OF THESE I'VE FIXED 40 OUT 44 POWER SUPPLIES. IF ANY OF YOU HAVE SOME SKILLS WITH SOLDERING. THE MAIN PROBLEM IS IN THE CAPACITORS. THERE ARE 3 SETS OF CAPACITORS THAT NEED TO BE REPLACED. 4 3300uf 35v, 8 2200uf 25v, 7 1000uf 10v. ONCE YOU REPLACE THESE YOU SHOULD BE GOOD TO GO. THE OTHER 4 WE HAVE PROBLEMS WITH ARE STILL POWER SUPPLY ISSUES BUT ALITTLE MORE IN DEPTH WILL POST WHEN WE FIGURE OUT THE PROBLEM.
This may be too old of a problem for anyone to still have one of these. I found that the computer control still functions, but, the screen circuitry warms up very slowly (like 20 minutes or more). If the TV changes to a mode that has no signal it times out and shuts down (See question about Invalid input message). The green light stays on and the screen dims. If you can get it in the right mode eventually streaks appear and tries to build a picture. Use the buttons on the front under the screen because when the TV gets this bad the remote won't be detected for several minutes. Locate the black switch on the back labeled 1 0. Flip it off and back on and full picture will return. The trick is knowing what mode its in. Change the capacitors as suggested
Hello? Do any one know where to get these original Astar parts?
Do any one know how many model of the Astar TV been make and the DVD including the portable? I worked in Astar Co as a eletronic tech before the company closed due to the bankruptcy.
I been help numbers of people call me every day please check my refencen. Any question call 323-767-6030.
I know I am late on this post but I had the same problem with an astar ltv-2601. I just replaced 8 puffed up(bad) capacitors in power supply and has been good since about 4 months. They went out of business because they copied philips design and were sued by them. You get what you pay for.
I sold the ASTAR for parts and bought a VIZIO over 1 yr. ago-no problem. Bought a 2nd VISIO over 6 mos. ago. and love 'em.
Dan, Glendale, AZ
Hello guys,
Okay, replace all the components? is not always works?
How about after replace all the coponents still show no pictures, WHAT'S NEXT???? CAN SOME ONE ANSWER THAT?
But I can. I know about this astar products better than everyone. Any question? Call 323-767-6030.
EVERYONE LISTEN UP, REPLACE THE CAPACITORS, AND YOU'LL BE FINE. My 2701 was out of commission for 7 Months, and I just replaced the Capacitors. Now It was my first time doing it. Just reviewed some YOUtube videoson doing capacitor replacements/removal, and I was good to go. Just pay attention to where the Negative STRIP is on Capacitors and Solder away, and if you want an all in one solution, scan ebay for Desolder/Soldering Iron 40w/Solder Type in Soldering Desoldering and its about 15.00. GOOD TO GO
Eclip66 is right, ive opened up my Astar TV aswell and have taken a look at the power supply, all of the capacitors he mentioned have bubbled tops (means they are blown) or are leaking their electrolyte all over the board.. in addition to the capacitors he mentioned, there are 3 other near the center of the board with little plastic disks covering them.. i checked these using an ohm meter and found they were also bad (they charged WAY to slowly and were also leaking) so in addition to the 4x 3300uf 35v, 8x 2200uf 25v, 7x 1000uf 10v.. you need 3x 100uf 450wv caps as well. Im in the process of locating some replacement caps and am about to change them out, if this solution does not work, and i find more problems ill be sure to make an updated post.. happy soldering!
-Jason
I worked for Astar Company as an electronics technician before they are closing down. I know all model of the Astar TV, the Astar portable and DVD player. Any question call 323-767-6030. Due to the heavy phone call and trying to resolve each problem. Remember, First come first serve only.
SOURCE: Astar LTV-2701 27
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected] if you require further assistance.
26" Astar LCD Television. 2 years old.
All of a sudden we have difficulty turning the TV on. when the light is flashing... turn it on... black screen and eventually sound. Turn it off, wait, turn it on, logo comes up and then shuts itself off. Turn off the main power switch and turn on, then turn on the TV and it will come on and work. Unless I follow this routine I cannot use the Television. I bought this TV at Best Buy. Who can I get to repair it for me since I wouldn't know a capacitor to see one let alone the right ones.
I can't find 100uf 450WV capacitors anywhere. Any suggestions? Thanks in advance.
Tv won't turn on. Had this a year ago and Astar sent me a black box for the back and it worked fine until a week ago. Where to I go since Astar is out of business.
keith
My astar is completely out now. I took it in and they said it was the
power supply. I have owned this t.v. for 2 years now and the first
year it was in the shop for 3 months waiting for a power supply which
was on backorder. Now a year later the same problem, except now they
can't replace the part they actually have to fix it, which would cost
double of what it would be to replace it. I don't want more problems
in another year, so I just bought another t.v. with an extended
warranty. Anyone know how to get the part, I would love to know, so I
can get some money back and sell it. Or if anyone else wants to buy it
for parts, let me know.
so yah i have done all the steps that everyone has listed already
and now i have no power going to the tv at all . the light does not even come on . and i have tryed everything but nothing even lights up .
so i dont have any idea upon what i can do
my tv does not turn on at all
i hear a whit noise when i put it in the on position but there is no picture
please help me with my problem
When I first bought this tv, I had the same problem. In addition, if it would come on, it had multicolored check pattern on the screen. The tv was replaced twice under warranty and after over 3 years am having the same problem. Am not very hopeful to get a solution. Neddless to say, I will never buy an ASTAR product again.
Dan
Glendale, AZ
power supply
I just bought one of these cheap that would not turn on. Previous owner said he had replaced the main power switch that was heating up. Said that worked for about two months and then quit again. Told me about this capacitor story on this sight. Benn in electronics for 30 years and this all just seemed like a bogus internet story.
Opened it up and the the switch had been replaced and this new one was bad too, plastic switch was starting to melt. I can just figure a cheap switch and really poor solder job. Replaced switch and monitored current with a really nice power meter. Tag says 200W, but tis only draws 132W on bright backlight and down to 62W on dark backlight. Not a sign of power supply problems. This has a really good power supply with power factor control. Surprised at the very low harmonics this introduces on the power line.
I have the same problem turning on my Astar HDTV, the power button is red an when I push the button it goes green and red again, I need to do this a lot of timessss, and the mayority of time I cant turn it on..... what can I do. IM from Puerto Rico, and I want to know if there is a solution to this problem...... pliz if someone can help me reply at my email adress: [email protected] I''ll be gadly thankful.
