Barcode on labels are clear and precise but will not scan. Everything was ok until someone changed the ribbon. The labels look great but will not scan.
Did you reset this printer to factory setting just visit this link http://blogs.scansource.com/zebra-zm600-how-to-reset-printer-to-factory-defaults/
if you have user guide plz flow that if you dont have it visit this link below
http://www.bluestarinc.com/techsupport/ZEBRA/Manuals/ZM400_600_UG.pdf
SOURCE: Zebra S4M Thermal Lable Printer Not Printing Correctly.
Is the Media guide st corectly?
This link is for a datamax but all label printers are stuctured the same way.
check
http://www.posguys.com/download/88230401_a.pdf
SOURCE: Zebra TLP2844 does not print the barcode label
Turn off the printer, then hold down the feed button while you turn it on again. After the configuration label prints, turn the printer off and on again,then try to print your labels.
If the barcodes still don't print, make sure they don't extand past the top, bottom or side of the label. If you software allows you to "clear the label cache" or "re-image the enitre label", try that.
SOURCE: Zebra LP2844-Z - no longer prints a barcode on a specimen label
Added ''3 of 9' font to C:/Windows/Fonts.
Opened Word document, selected 3 of 9 as Font and typed a word.
Went back to printer and it printer the accession number and barcode.
SOURCE: I need the exact ribbon and label model to buy for TLP 2844 barcode printer
Contact Labeltronix at 800.429.4321. One of our sales reps can help you with your label/ribbon combination for your application. www.labeltronix.com
SOURCE: We have a 9855 Monarch barcode Printer. We are
If the printer display just shows Ready, but doesn't print, there could be a few things wrong.
1 - no data is going to the printer
2 - data is going to the printer, but it is not the printer's native language
3 - cable connectivity issues
4 - wrong cable is being used
5 - if wireless, data is not going to the correct IP
If using a 3rd party application, make sure that you've chosen the correct Monarch printer, as well as printing to the correct port. Sometime people print to LPT instead of Serial, as an example.
If using 3rd party drivers, make sure of the same thing.
To see if the printer actually works, press both of the arrows on the display, at the same time, after the printer is at the ready screen. As long as have the printer configured correctly (ribbon, supply type, etc.), the printer should print out a couple of labels.
I tried reseting the factory settings but that didn't work either. The odd thing is that some bar codes do scan and of those that will not scan were able to be scanned when printed to a HP document printer.
You have to be sure you are using a resin ribbon and NOT a dye-sub. The resin has carbon which is detectable, dye-sub does not.
