Keyboard stops working in the middle of using it.
Hi There,
You've got yourself a broken keyboard. More than likely the connection from keyboard>mainboard is worn or broken, resulting in failure during use. The easiest way to solve this would be to purchase a new keyboard and replace it - http://www.aliexpress.com/fm-store/908032/211153434-513256609/laptop-keyboard-for-HP-Probook-4530S-4730s-US-keyboard-NSK-CC0SV-9Z-N6MSV-001-638179-001.html
You also have the option of using a USB keyboard.
SOURCE: sir I Purchased a new
my recommendation is that you should not switch to windows xp because now a days laptop are better compatible with windows 7 and as for the lower version of software that are not running try getting higher version because newer version will always have some improvement
SOURCE: HI, My name is tonny, i
The HP you have doesn't have a SIM card. Those are for phones or network devices.
Hope this information will help.
Your response is very much appreciated...Thank you for using Fixya...
SOURCE: HP ProBook 4530s don't start. Lights blinking!!!
Sub out the ram one at a time, if luck is there unit will start, second option is remove the main battery often loads the system down.
Take it to a service shop asp, key board will need to be replaced, and the laptop will need to be assessed for motherboard damage.
SOURCE: Space bar is not working in my laptop..My laptop is HP ProBook 4530s
You should replace the keyboard. Either bring it in to a PC shop, or buy a replacement keyboard yourself and follow these instructions:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=5060880&prodTypeId=321957&objectID=c02907532
