Spyder 03-05 Chevy Silverado Vertical Grille Fits 06 1500, 05-06 2500 3500 Hd Only Logo
Jarmon Scott Odom Posted on Jun 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My automatic windows wont roll down
I redid my door speakers and reconnected everything correctly. my power controls wont work on the drivers side only. i can only move the drivers side mirror. the power windows wont work, the right mirror wont work, the power locks wont work, and the window lock wont work, the light wont even come on.
raj somaiya
Level 3:
  • Master 5,370 Answers
  • Posted on Jul 04, 2012
raj somaiya
Master
Level 3:
Answers
5370
Questions
0
Helped
3569306
Points
14579
Click the link below to troubleshoot the problem:--
Power windows not operating?http://whoisbyme.blogspot.in/2012/05/car-window.html
Thanks.
I have a 2001 Toyota corolla with power windows. Now every time I want to roll down or up my windows I have to open my drivers side door in order to roll any of the windows up or down in my car please help...
It sounds like there is a connection problem with the wiring going to the Master Window Controller on that door. It may just be a case of reconnecting the wires which may have become loose.
2002 gmc envoy windows roll down and up by themselves
The power windows on your vehicle are controlled by an electronic control module , as are the power mirrors !
Power Window System Components
The power window system consists of the following components:
• Driver door module (DDM)
• Passenger door module (PDM)
• Body control module (BCM)
• LR power window switch
• RR power window switch
• Window up and window down relays in each of the rear passenger window switches
• Window lockout switch
• Reversible power window motors in each of the doors (circuit breaker protected)
• LT DOOR CB 25A (System power for left rear window)
• RT DOOR CB 25A (System power for right rear window)
Your best bet , take your vehicle to a qualified repair shop.
1helpful
Power windows locks and mirrors
Sounds like the master switch is not plugged in properly, this is the switch in the driver's door.
Front driver power window wont roll up
So , what did you do wrong when you had the panel off ? How do we know what's wrong .
MY 2006 DOdge ram Thunder Road's windows dont work. They used to work i bought the truck new. All of a sudden all the windows from every control dont roll down their own windows as well as the driver side...
your truck also has power relays working with the fuses. each door has its on circuit except the main controller in drivers side door. if u cannot control anything from drivers side then look at the relays for possible cause to your problem.
Drivers Door Window/Locks aren't working
driver side lock and window switch... if its all one unit... i had a 95 cherokee laredo that did that... changed the switch and it fixed my problem...
I have a 2001 rodeo. the power windows all work from each window if you hit that particular switch at the window, they work. the drivers side window also rolls down. but the 3 other switches at the drivers...
First check your fuse panel. Other than that...Perhaps moisture has gotten in the door panel and messed with the connection. I would take the panel off and investigate..make sure everything is plugged in.
2answers
1994 jeep grand cherokee power window problem
most of the time it is wires in the drivers door that break in the loom
2helpful
Power windows isuzu rodeo 1999
Cable must of disconnected need to take door cover off and reconnect...
12helpful
4answers
2004 Jeep Grand Cherokee driver side power windows do not work
I had the same problem with now power to windows, mirrors and seat. The common soulution is the orange and or black wire in the boot have broken between the door and post.
Top Spyder Heating & Cooling Experts
Paul Carew
john h
Are you a Spyder Heating and Cooling Expert? Answer questions, earn points and help others
