Question about HP PSC 1610 All-In-One InkJet Printer
Refilled color cartridge and now the menu screen says the check cartridge and it won't print?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
You damaged the gold contacts. Now you have to buy a new cartridge.
Posted on Jun 07, 2012
  • dandogg
    dandogg Jun 07, 2012
    thanks kate! are the gold contacts on the bottom of the cartridge? also, it printed right after i refilled it then it started acting up.
6ya staff
SOURCE:
My printer won't print in color
Dear please refill your colour cartridge or replace your cartridge or purchase the correct cartridge No.
Dec 10, 2012 | HP OfficeJet 6210 All-In-One InkJet...
My magicolor 2550 won't print in color
PLEASE CHECK ON PRINTER PROPETE AND CHECK MARK BLACK
Apr 13, 2012 | Konica Minolta magicolor 2550 Laser...
My canon mp160 printer has the color light blinking (I checked to make sure it has ink and the cartridge is in correctly) and won't print color. Thanks for any help.
Usually the cartridge is out of ink in which case get it refilled or it may be electrically failed in which case you will need to buy another cartridge.
If putting a refilled cartridge in the machine you will normally get some kind of error code, to clear this, press and hold the resume button (Black with red circle with an arrow head pointing towards you) for about 10 seconds then release it and usually you can print. The orange light will however stay illuminated or flashing.
Sep 11, 2011 | Canon PIXMA MP150 All-In-One InkJet...
My printers color won't work, I just filled it with 4.5 ml of each color. the black is also really patchy. I want my lexmark z1420 to just work!!! Help!!!
It could be due to the refilled cartridge in your printer. Refilled cartridges tend to degrade print quality and in performance. Try to replace your cartridges with genuine Lexmark cartridges.
Sep 05, 2011 | Lexmark Z1420 Printer
I have changed the colour ink on my canon mp460 but it still say empty
CL41, this is the one you are using for your cartridge.
Did you change your cartridge with brand new one or refilled one??
If you did with refilled one, the ink level won't go back with full.
This is the method how printer measures the ink level.
1. Each cartridge has a serial number.
2. As soon as installation in printer, printer recognizes the cartridge by serial #.
3. And the printer starts to count the printing document.
4. After reaching certain print counting, the ink level will show "low ink"
So my answer is even if you refilled your cartridge, the ink level won't change,
since printer cannot weight the cartridge or.....some other technology to measure each color ink level.
Thanks.
Jun 15, 2011 | Canon PIXMA MP460 All-In-One InkJet...
U051 error message. Won't print
Well, you must be using PG30, CL31 cartridge for your printer.
Did you refill your cartridge?
For error 051 means printer is not reading the cartridge. (cartridge is not readable)
When you put refilled cartridge, that's what it happens.
(after 3~4 times of color refill, color cartridge is no long to use, only applies in Canon
and there is no solution for it.)
Pls replace with new one.. and will work again.
Or if you need to refill again with other cartridge, pls....unplug your printer before you taking out the cartridge. In this way, you can re use your cartridge. Little trick... but no solution will work, once cartridge is not readable.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 11, 2011 | Canon PIXMA MP470 All-in-One Printer
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
99 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
