Top of tv screen has a black line and top of tv pict is squashed
When you look at the picture there is a big black line on top and squashed the picture on top. then it looks like you are looking at 2 pictures put it is one.
Re: top of tv screen has a black line and top of tv pict...
Nothing you can do unless you have knowledge of Solid State Electronics Servicing. Looks like a couple of Capacitors in the Vertical Deflection Circuits have become bad.
Good Day, LDS also; You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Most if not all DVD's are 16 by 9 even in 4.3 mode you are going to have those bars on this TV. Some television have a zoom feature to get rid of that but not this one.
To properly diagnose this problem,access to
the servicer menu will be important.Also,the
service literature for the horizontal and vertical circuits may be needed.Contact a tech
who can help you that is familiar with Durabrand.
The vertical circuit is going bad,this is the one in charge of opening the picture up and down,try taping on the side to see if the picture reacts ,if it does your set has a loose conection and the vertical IC will need to be resoldered only but if it does not react the IC will have to be replaced,if you are familiar with tv service this will give you a place to start but if you are not be safe and seek the help of a servicer,please let Us know how it goes.
