I can only assume it's because you have no water connected to it. Some washers have a pressure switch that won't allow the machine to turn on without it being connected...try it and see what happens.
Thank you! but I do not have hoses that connect to check. Is there a way to test without hoses?
i'll look into it and let you know what I find.
Thank you!!
SOURCE: Maytag Neptune MAH9700AWW - no power to pump.
Check water level switch, pump motor relay that activates the pump.
SOURCE: How do I open my maytag Neptune MAH9700AWW front load washer?
first get access to the back of it. find the screws that hold the accsess panel on unscrew and look underneath. its on the bottom.
SOURCE: Maytag Neptune MAH9700AWW: No water to fabric softner cup
CHECK THE WATER VALVE
[email protected]
SOURCE: Maytag Neptune Front Loading Washer MAH9700AWW
2E Voltage for motor control bus is over or under specified limit. Replace PCB
Here is the service manual for this unit: http://www.applianceblog.com/manuals/16025909.pdf
Here is the technical manual for this unit: http://www.applianceblog.com/manuals/16026736.pdf
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Hello! I have Maytag Neptune MAH9700AWW. I did not turn it on for a long time.
And now, I can't do it. Main-board have 112-115 v. I check a sensor on the door and power filter, its OK. Tell me please, what could be the another reason of non turning on?
