Door seal does not seal at bottom of opening side.
SOURCE: I have just replaced the door seal on my freezer
Hi yestermorrow,
Thank you for using Fixya. A nifty idea you can try is to adjust your front level feet upwards. This will allow the door to lean against the fridge. It does not need to be adjust upwards too much though. It is a solution that will make sure the door seals against the fridge, as well as not having to replace anything.
Another thing you MUST do is run boiling hot water all over the seal (Remember towels for the spillage) This will allow the rubber to expand, and become soft for extra sealing.
To answer your question regarding how it locks, it locks with suction. If the seal is sealing all around the door area (Soft seals a must for good sealing), it will create a semi-vacuum area inside the fridge (Thus the sucking sound when opening a fridge door)
I really hope this has helped you. :-)
* If you found this solution helpful, please rate it.
