Product works fine for my husband, but when I get on none of the programs will work, it acts like no one is on it. I am under 100 pounds and wonder if that is the issue that the lower weight will not keep the system charged. Will a new battery work? or a power cord that keeps the battery charged?
A new battery will more than likely allow you to use the machine, but the lighter weight is not recharging the battery correctly. I would suggest replacing the battery and possibly adding an external charger. Repair Parts for Stairmaster Equipment Batteries Springs Belts Chains...
SOURCE: stairmaster climber model 4600 pt pedals go all
Unplug dc power connection then remove right side panel check for loose connections on on alternator, check distance of speed sensor to speed sensor disc you should no more than 3 credit card distance between them. Next remove the black wire from the B+ terminal on the alternator, then remove the brown wire from the field terminal on the alternator.Place a short wire with alligator clips between B+ and field terminals start stepping for about 10 to 15 second you should full resistance in that case its the upper console that if not replace alternator
SOURCE: Stairmaster freeclimber 4400 pt will
Remove console knobs form the back of the console, lift the up, and disconnect the 20 pin cable from the console. Get a multi meter go to dc volts 100v range. On the connector you will be testing for 12 to 19 volts. When Looking at the connector the connector nipple should be pointing left starting form the bottom left odds numbers right bottom even you will hunt for pin 1 Neg pin 10 Pos. If all voltage readings are within 12 to 19 volts and the console is not powering up , then either replace or have the console repaired.
National Gym Parts can help with process go to http://www.gympart.com/
SOURCE: stairmaster freeclimber 4400pt how to fix slipping
This could be the hub assembly slipping I would replace this assembly and the pedal chains call National Gym Supply @ 800-496-7278 and get pricing for the hub assembly and step chain ( L & R )
SOURCE: I HAVE 44OOCL FREECLIMBING STAIRMASTER AND NEED TO
Since Stair Master/ Schwinn was bought out by a company called Fit Dragon Int'l, but Nautilus may have the info to direct you to obtaining and owner's manual call them @ 1-800 846-1270
SOURCE: When my wife uses stairmaster
hi
just check the speed of unit if she goes faster than when she was on level 17-or 19 it is ok
if not calibrate the tension but i think it is always feels like this
let me know
