Question about Toshiba Portege Tablets & eReaders
Toshiba Portege M400, do all models support pressure sensitivity?
Im looking into buying a Tablet PC for draing/art related stuff, its a must that it supports pressure sensitivity, do all the M400 series support it? cheers
Anonymous
SOURCE:
Bfsas1
Brett McGuigan
  • 258 Answers
SOURCE: Recovery CD
ok you wouldn't have been supplied a recovery cd, you have to create it, to create one have 2 blank dvd discs ready and go to start menu and select help type in a search for recovery cd, this will explain how to create one....if your computer won't load into windows you will have to re-install windows again, cheers, any other probs please get back to me.
Brett.
Posted on Dec 30, 2008
Anonymous
SOURCE: toshiba M400 tablet wont start
I've had this problem intermittently on my Toshiba M400, and it recently became bad enough that it was failing to start on most attempts, and crashing soon afterwards if I moved it. Prodding the heatsink to change its position may have helped, but this could have been due to chance. It also had a habit of resetting itself when leaning on the left side of the keyboard when typing, but not when using an external keyboard. It's always had occasional crashes under high CPU load, causing the machine to freeze and the fan to go up to maximum. BIOS updates improved this initially, but in recent months it got worse again, especially when using Virtual PC unless hardware virtualisation was disabled.
I've just stripped down the laptop using the guide suggested by thiscomputer at http://www.irisvista.com/tech/laptops/Toshiba-Portege-M400/take-apart-tablet-pc-1.htm (good find!). Many parts are more fragile than in a desktop PC, but otherwise if you're used to taking stuff apart it shouldn't be that big a deal. You'll need a normal and small crosshead screwdriver (jeweller's screwdriver set works fine) and space to lay out the screws in a pattern so you remember where they go - consider making notes.
I fixed two things that could have been a problem: Firstly, a fair amount of dust was blown away with a hairdryer and vacuumed from the heatsink. Secondly, the pink thermal grease that couples the CPU to the copper heat pipe appeared to have all squeezed off the CPU die and had accumulated around the sides, possibly due to the small freedom of movement in the heatsink being repeatedly shaken. The grease was still soft so could be scooped back onto the die with a flat-bladed screwdriver. I also bent the legs of the Y-shaped CPU-to-heatsink retaining clip so that there was a greater downward force on the CPU. I figured this would improve thermal contact, especially if the clip had naturally bent and come loose over time. Removing the CPU itself didn't show any damage, but might have improved the electrical contact when reinserted. Be careful when screwing the Y-shaped retainer back in - because of the springy nature of the legs, if the screwdriver slips the screw will fly across the room and you'll have to hunt for it :-) The other thing to note when reassembling is that the wi-fi on-off switch engages with the lug on the motherboard, if this is wrong you won't be able to move the switch and the actual state will be the opposite of the switch position.
Finally, after I reassembled it still refused to start. I noticed the DVD drive wasn't properly flush with the case, and on removing the DVD drive it started. Close inspection of the drive and laptop connectors revealed a small metal tab had come loose, and the laptop continued to work with this tab removed and the drive reinserted properly. I removed and swapped some memory modules while experimenting with the DVD drive which also had some effect - it's possible that an ill-fitting DVD drive bends the memory above it and affects the contact. It's entirely possible that this was the only problem to begin with, and that playing with the CPU made no difference, so maybe check this first! But whatever it was, happily my m400 seems to be operational again.
Posted on Apr 11, 2009
anjana03
Roshan Rijal
  • 361 Answers
SOURCE: Touch Screen not working or Pen?
in my opinon. you should be re instal this touch pad driver.
Posted on Jun 13, 2009
Anonymous
SOURCE: My toshiba portege M400 laptop will not start up,
This happened to me. The computer will not work with the battery in it.
Solution: Take battery out and plug in without battery... It should work,
You will need to get a new battery
Posted on Dec 10, 2009
Anonymous
SOURCE: how can i enter the bios environment on toshiba po...
hold the "esc" key presed during boot, and then pres the "f1" key and you enter to the bios
Posted on Jun 15, 2010
Remove password bios toshiba portege m400 please!
Here is a guide toremove windows passwordwith Windows Password Recovery Tool Professional from http://www.windowspasswordsrecovery.com/Step1: Download and install Windows Password Recovery Tool.
Step2: Burn CD/DVD/USB Flash Drive. (Namely it is to burn a Windows password reset disk.)
Step3: Set the target computer boot from CD/DVD or USB.
Step4:Remove the forgotten Windows passwordwith the burned CD/DVD/USB. Then log on to Windows without a password.
Of course, you can also finish Windows password remover if you have a password reset disk in advance. That's also an easy solution.
Source: http://www.windowspasswordsrecovery.com/windows-password-remover.htm
Aug 13, 2012 | Toshiba Portege M400 PPM40U01000E Tablet...
I have install win 7 on portege m400 , but pen not working! Please help me!
Go to the Toshiba Mobile support web site for you exact model. Select Drivers download. Select Windows 7 32bits or 64 bit and download the latest versions of all that relate to the Tablet module, and that includes the Wacom driver.
If you Windows is genuine you can uninstall all the Wacom drivers then execute the Check new hardware wizard ( of Hardware changes) or even Windows Update
Jul 06, 2011 | Toshiba Portege M400 PPM40U01000E Tablet...
I have a Toshiba Portege M400. The problem is that when I go near the fron microphones I get a loud and wining feedback noise. Have you had this problem before? It seems strange. Can you help?
Turn the sensitivity down in the sound mixer?
Right hand mouse click on the loudspeaker icon and choose recording mixer. Adjust as required.
Hope that helps.
Dec 09, 2010 | Toshiba Portege M400 PPM40U01000E Tablet...
WHERE IS THE SLOT TO UPLOAD MY 512mb SIMCARD ON MY TOSHIBA LAPTOP
take a closer look left or right side of ur laptop u may find it there
Oct 25, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
Toshiba m400 builtin hard is offline
Did you look at the BIOS setting? Try hitting Esc then F1
Jan 27, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
Toshiba Portege 500 Laptop
need a toshiba mother board for m40x250
Aug 04, 2008 | Toshiba Portege M400-S5032X Tablet PC
Tablets & eReaders Logo
59 people viewed this question
Top Toshiba Tablets & eReaders Experts
Ekse
Thomas F. Schneider
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
