Washer stopped working all together
Hi,Check your water solenoid valve, the part where you connect (2) hoses, could be burnt out, sometimes they do, especially if your water pressure home (building) is low, or could be your motor, remove back of machine and check water valve, check valve with ohm tester, or visual check can tell you, if burnt out, replace it, few things could burnt out, motor, capacitor, switches/relay etc, but first check water intake (solenoid) valve, also,check / reset, fuse/circuit breaker, probably went of, when burning smell occurs, ( happened) if it's not your water intake valve, let me know, we can check other possibilities. but i believe it's your valve, good luck.
I have the same problem
