Sony KDF-E60A20 60 in. LCD HDTV Logo
alfred Posted on Jun 08, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
56 flashing green light then continous red light
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Jun 09, 2012
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986771
Points
237762
Endless blinking of standby LED to Sony TV indicates serial clock-serial data bus has failed. Actually serial clock signal is there OK, but serial data is not. A very skilled work indeed. A thorough checkup should be done. If you are handy, check this site. The site name is "Electro-help". Type in this site name to yahoo search box. Pull up older posts there. All details are given with explanations.
1 Related Answer
Anonymous
  • 17 Answers
  • Posted on Feb 03, 2010
SOURCE: Sony KDF-E60A20, buzzing sound, lamp light flashing red continous
It may be the ballast....
2answers
The red and green lights are flashing continously and it won print
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
1helpful
2answers
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Flashing "Standby" light??????
KP53HS10, NO PICTURE OR SOUND , ONLY A CONTINOUS BLINKING RED LIGHT ON CONSOLE. CAN YOU HELP ?
I have a 56" samsung rear projection tv that won't turn on. the red standby light is lit and when i push the power i hear two clicks and the green timer light flashes quickly then the green led stays lit...
I suspect you probably have a bad LED assembly. It could be either the red, green or blue that is bad and give you the same symptom. The problem is locating parts for it as it looks like the light engine is no longer available. I would have a technician look at the TV to verify this and what parts are needed for repair.
1helpful
Zenith 56" DLP Z56DC1D won't turn on
Replace Lamp and CK both Fans to make sure they are running.If Fan behind Lamp does not run TV will not light LAMP.
2helpful
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
