Ricoh 1232c i have the code sc672 and i tray to go in service mode to reset the code but when i press stop 107 stop dosen”t do nothing i don”t have a response from operation panel
SOURCE: Ricoh Aficio 1232c is flashing SC 792
that appears to be a finisher communication problem. Check the connectors..
SOURCE: ricoh 1045 error code sc 672, 961
Controller to operation panel comucation error at start up.Check the controller stall,controller board installed correctly operation panel connectors.Enter im the service menu ,press the SP mode,open the front door,turn off the copier,unplugged the machine.Wait 10 seconds,plugged on the machine,close the front door,turn ON the copier and make a copy.
SOURCE: Ricoh Aficio 1232C RPCS When I try to print the re...
when you selected auto tray was that in the driver or microsoft settings ? microsoft settings will overide the copier settings driver. look under file then page setup to see what it is set for.
SOURCE: Problem with the Ricoh mp c2800 Ricoh error code
If the model ia a MPC 2800 it a controller board issue maybe the operation panel. -carl
thanks i know this but even when i am doing this is not going in service like the panel is not responding on nothing
