SOURCE: zhone linksys router
I had same problem but I think it's more of a simple solution. Linksys default IP it uses is 192.168.1.1, and guess what...so is the zhone router. I changed my linksys router to 192.168.10.1 and i am able to connect to the internet. Only problem I have left is some things are not working such as MSN messenger and https pages. I am wondering why...
SOURCE: My Zhone 6211-I2-302 is not listed on port forwarding router list
I have a Problem in opening port 81 :(
how can i open it
SOURCE: I cant open port for Zhone 6211-I3-200 Router
Some times you will need to open the Logical Ports on the router.
These are the logical ports.
For this you will need to open the set up interface of the router.
Once you open the set up interface of the router, you will be able to find the settings on the router where you can open the ports for the particular program.
If you are opening the ports for a special device in your network, then you must know the IP address of that device.
For example, wireless camera, DVR, X-box, Play station ...
You can choose the option PORT FORWARDING for a special device application.
If you just want to open the ports for all the network, then you can choose PORT TRIGGERING
Click Here for more info
Use the following link to download the driver
