Sewing Machines Logo
Anonymous Posted on Jun 09, 2012
I need a manual and a bobbin case for a new home model 764
The model number I find on the machine is 764 and serial is 107, however I cannot find anything on line with these numbers. I purchased this machine at a moving sale...maybe the wrong numbers?
Debbi's Sewing Machine Repair
Level 3:
  • White Sewing Master 7,365 Answers
  • Posted on Jun 09, 2012
White Sewing Master
Level 3:
Answers
7365
Questions
Helped
1742630
Points
19451
Http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
I need a manual and a bobbin case for a new home m - p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Aug 16, 2007
SOURCE: needle picks up bobbin thread but then thread gets stuck
I've had similar problems (as well as other problem with the thread breaking all the time and the "shuttle race" thing that holds the bobbin falling out. One very important thing that isn't mentioned in the manual but that the salesman stressed is that you have to use only "Schmetz" brand needles. They are a tiny bit longer, but that makes all the difference in the world if your stitches are skipping. I forgot and used Singer needles and had horrible results.
Anonymous
  • 56 Answers
  • Posted on Nov 12, 2007
SOURCE: thread getting caught around bobbin case
It isout of time you need to time it.by adjusting the screw on the bobbin holder turn it left or right and the tension knobe and foot tension.
Anonymous
  • Posted on Nov 29, 2007
SOURCE: Getting the Bobbin threaded in the Machine
when this has happened to me, the upper thread has somehow run amuck. check to make sure the top thread is STILL routed properly. It might have nothing to do with the bobbin.
Anonymous
  • 323 Answers
  • Posted on Oct 14, 2008
SOURCE: Bobbin Case will not snap into housing
Insert the bobbin case without a bobbin to see if it will go all the way into the locked position. If it does,the bobbin case and basket are okay.
Check inside the bobbin basket(where the bobbin goes) and see if there is thread or lint wrapped around the spindle the bobbin case sits on. If there is, remove it. If there isn't ,then the bobbin is probably sprung and needs to be replaced.
sewman7
Anonymous
  • 111 Answers
  • Posted on Jun 11, 2009
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
1helpful
I need a manual for a New Home 108 model number sewing machine. Serial number 330019370
New Home machines are part of the Janome manufacturing line. Try this site: https://www.janome.com/en/support/retired-machine-manuals/ . There is a manual for the 107 and 108 here: https://www.janome.com/siteassets/support/manuals/retired/other-models/inst-book-107--108.pdf . You can purchase a pre-printed manual from several sites, including https://www.sewingpartsonline.com/instruction-book-janome-and-newhome-108.aspx .
I hope this helps.
I'm looking for a replacement part for a Husqvana exelsior sewing machine . Serial number 31084. Can you help please. ?
That's a bobbin case. Search for:
Make Model bobbin case
or check with a local Husq/Viking shop
Singer 9420 bobbin case diagram
Could you check to see if that is the correct model number? I cannot find anything on a Singer 9420.
New Home Type F threading bobbin take up
Perhaps one of these will help:
New Home Model 532 Sewing Machine Threading Diagram
New Home Model 2022 Machine Threading Diagram
Thread Bobbin on Newhome Sewing Machine
HINT: install a brand new needle. Remove the top thread from the machine. ALWAYS RAISE the presser foot and then rethread the top thread. The upper tension should start out set at the midway point. Use only fresh, good quality thread--AVOID old or bargain bin threads.
If the machine is threaded correctly top and bottom, but is still not catching the bobbin thread, then it's possible the machine is out of time. Search for sewing machine timing or take it for service.
Since it is an older mechanical machine, it is recommended to clean and oil the machine frequently. Oil Before using it if it has been in storage. If the machine is sticky, motor drags, etc., here's a good reference for getting it back in shape:
Wheel on right side that controls the needle up and down is very tight...
Looking to download a Janome/New Home Deluxe Model 534 manual.
a sewing machine must have a bobbin case with a bobbin in it to sew.
I don't know any where you can get a free manual for a new home free, but you might check with Janome sewing machine website & ask them
if they have a free manual for the machine, I won't promise they will.
here are a few websites for parts & manuals for sewing machines
sew4less.com
sewusa.com
sewvacdoctor.com
a1sewingmachines.com
ebay
Singer 5528...help please!
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 5528) & click search
and it will bring up the manuals that are available
try checking the bobbin case for burrs & make sure the the small bar on the bobbin case is not bent
make sure the bobbin case is in correctly
Hi. I need a new bobbin case for a New Home Model
Standard type bobbin case that can be bought on ebay or any sewing machine shop
Top White Sewing Sewing Machines Experts
ZJ Limited
ZJ Limited
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
