Yes and also possibly the low ohm resistors. You can get the PT53WX53 convergence kit which fits your model from www.tvrepairworld.com which has the 2 ICs and associated resistors plus the CD with repair instructions.
SOURCE: CONVERGENCE ic CHIP
I replaced the Convergence IC Chip STK392-110 for my PT-53WX42 Panasonic HD Rear Projection TV but I found burnt resistor(resistor #)R7053,R7002 & R7005.Can someone tell me the part# ,description,resistor value and power rating.I don't have the schematic to look .Thanks
SOURCE: need part # for convergance IC chips
they should be stk392-110. if you look in your set they are located on the left side of the chassis on the huge heatsink. you can get the numbers off the ics its big enough to see. you can get them at the following link for about 9.00
http://www.yahoo.com/
SOURCE: IC Convergence on a Panasonic PT-51HX43
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
SOURCE: Replace IC Convergance chip in Panasonic PT-56HX41PF
Enter the tip of a pointed knife between the left side edges of the connector (circled in black in the attached pic) and gently tilt the knife away from the connector. Do the same on the right side. The connector should pop up.
SOURCE: panasonic pt-53wx53g vertical output ic
IC451 (Vertical Output) LA78045 part number is C1AA00000521
Available in Part Store.
Above info are taken from related service manual and an image of s.manual is given below...
