We tried replacing the filter, but didn't make any difference.
Sounds like either the water valve is bad or the line is plugged or frozen somewhere. To check the valve pull the water line off where the water feeds the reservoir have somebody try to dispense water you should have water coming out.If not try to dispense water again and listen for a slight buzzing noise if you hear the buzzing noise and you get no water the valve is bad.Always check the lines for freezing or restrictions before you replace the valve.
SOURCE: My maytag water dispenser not dispensing water
I am sorry I can not find a model listed Maytag Email me with the correct model or visit my site to see where to look for the model numbers.email is [email protected] is below, Thanks, Sea Breezehttp://servicepartstec.blogspot.com/
SOURCE: Our Maytag icemaker stopped making ice suddenly
Does the water have a good flow ? Did you try putting the old filter back in ? Never change the filter just because a little red light comes on . Only replace when the ice cubes get small or the water dispensor flow gets slow . I have found new filters that were bad . Distributors make a lot of money for filters just because of that little red lite . Not just maytag , but all other brands also . Try pouring about 1/2 cup of water into icemaker . If it dumps the cubes but doesn't fill , replace the water valve . If it doesn't dump , and holds the cubes for a long period of time , replace the icemaker . Also , you may need to clean the coils of dust , lint , etc....
SOURCE: ice maker will not dispense water or ice.
sounds like maybe the switch that is press to release water not working so it doesnt sent the signel to let water out dispenser
SOURCE: Maytag Model MSD2651HEW - Changed Filter and
Was the pressure ok before you changed the filter? The water valve itself could be partially plugged or the supply line may be filling with minerals. Usually happens in the piercing tap used to attacc to the house line. Difficult to say for sure without seeing the way it is installed. If it was just the drinking water I would suggest the reservoir being froze up but since it affects both look at my initial comments...
Eric
SOURCE: Ice & water dispenser stopped working, lights are flashing
Replace the 2 capacitors on the control board
