There could be many options for u to check out this problem.as it could be the faulty fuse in the tv.its not to costly to replace it.aNd u said the click click noise that could be any of the capacitors getting short on the main board of the tv or they r slightly bursting on the board due to extra voltage.just have to be replaced to solve the problem.
The fuse in the tv is blown off please check that fuse and replace.
fuse tested fine.
For some reason the original post was garbled.
The problem: Flashing red light and a intermittant flashing green light. The green light eventually goes out and the cycle begins again. Utimately both lights become solid and turn off completely. The cycle will only start over when power is unplugged and re-connected.
Clicking sounds (which have been normal on startup) can be heard.
